Question about Singer Pixie Plus Sewing Machine
The upper and lower thread are not locking together in the fabric
When i start to sew it seems like a perfect stitch but then i realize the upper and lower thread are not locking together in the fabric. What to do?
    Problem Solver:
  • 6 Answers
The easiest possible option is that the bobbin is not threaded correctly. This happens to my students and 99% of the time the bobbin thread is going the wrong direction, ex: it's flipped to go counter clockwise instead of clockwise.
Posted on Apr 14, 2014
    Scholar:
  • 81 Answers
Check to be sure the needle is in securely and correctly. Also, make sure you are using the proper type needle. There are various types, depending on the type of fabric. The suggestion regarding the bobbin being put in right is very good. Sometimes you have to bring the thread over the bobbin case in a certain way or it won't work.
SOURCE: Singer CE-100 Embroidery thread bunches up underneath fabric
I had this problem and it all came down to using the wrong backing. I kep trying to use tearaway on everything but WRONG. Using the proper backing corrects most problems. Good Luck!
Posted on Dec 28, 2007
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 20 Answers
SOURCE: I have a Singer Sewing Machine 5817C, the thread
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
Posted on Oct 14, 2009
SOURCE: thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Posted on Jan 25, 2010
SOURCE: have dificulty ftting the bobbin holder in a singer 974 machine
I need an illustration of the correct installation of a bobbin case for model 7422
Posted on Jul 18, 2010
My thread keeps bird nesting on the bottom of my fabric what am I doing wrong? What are the correct settings for a straight stitch?
Is your bobbin threaded correctly? You should be able to pull out the thread slowly while feeling it very slightly holding back. It should not pull out easily or quickly.
Could be something wrong with your tensions, try adjusting the upper tension first by starting at the middle setting and working gradually higher and then lower till you get a neat even stitch.
Nov 29, 2015 | Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
How to adjust tension on lervia sewing machine
Tension is a balancing act between the upper tension and the bobbin tension. Balanced tension (which is not always necessary) is when the two threads meet between the layers of fabric. Not all unbalanced stitches are a tension problem. You can have loops under the fabric from a failed take up lever, improper clearance between the positioning finger or even a burr or lint. First I check the upper tension. If you can not make the upper tension normal pinching the thread after it comes off the spool will act as a tension device. If this solves your problem then start with cleaning.
You may have lint between the tension discs at the top next to the take up lever. Clean this out with the presser foot up. Next install a new needle size 80 and thread the machine. When you lower the presser foot and pull the thread the spring steel the needle is made of should bend 1/8 of an inch at normal tension. Between 3-5. If this does not happen turn to a larger number on the tension assembly. If this does not deflect the needle as you pull the thread to the left rear of the machine your tension assembly needs repair or replacement.
The bobbin tension is controlled by a spring on the bobbin case or bobbin basket (depends on the sewing machine). This spring can also get lint under it. The lint can hold the tension discs open causing no tension. This may be the problem if you see the lower thread pulling up to the top of the fabric. Normal tension on the lower thread is usually 150-200 grains. That may not mean much to you and you may not have a scale to measure that. One simple trick is to take a wooden clothes pin and glue 3 pennies to it. I then use this as a weight to set the bobbin tension. I clip the clothes pin to the thread and set it on the work bench. Next raise the bobbin case or bobbin basket without touching the thread or bobbin. Then tighten the tension screw on the bobbin case until the clothes pin lifts off the work bench.
This gives you a good place to start on balancing the tensions. Set up a straight stitch at the mid range of 2-3mm long and sew. Turn the upper tension dial to the mid range 3-5 and observe the stitch. If the bottom of the fabric shows too much top thread tighten the upper tension. If the top of the fabric shows too much lower thread loosen the upper tension. I recommend playing with your tensions to learn what too loose and too tight a tension look like. Sometimes we want the upper tension really loose to do a basting stitch. If you want to pucker (gather) you can create a long stitch and play with the tensions. A tight upper tension will pucker thin fabric. You can also gather fabric manually by using a long stitch and a loose upper tension then bunch the fabric together on the loose threads.
After all that it may be easier to take this to your local dealer and ask for advice.
Have a great day and keep on sewing.
Jun 22, 2014 | Sewing Machines
I have a singer sewing machine model 5805. i have a problem when i start to sew the cloth, the upper thread seemed ok, but the lower stitch was twisted in random ways. pls help thanks in advance.
When you begin the stitching, hold on to the thread tails and lower the needle into the fabric. Hand walk a couple of stitches and then use the power pedal.
Some use a "leader". This is just a small scrap of folded fabric that they begin the stitching with; stitch off and then start sewing their project. The leader thread is cut and used over and over until it resembles another term for this method - a "spider".
Mar 24, 2010 | Singer Sewing Machines
Skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Mar 14, 2010 | Singer 5062 Mechanical Sewing Machine
Skipping stitches and knotting up underneath.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you’re using.
Hope this helps.
Sep 23, 2009 | Janome Sewing Machines
I bought a second hand Juki industrial machine , model DDL 5550-7, but struggle to get the tension of the stitches right. where do you set the lower stitches tension
upper tension sets the lower thread tension (upper thread is what you see on the underside of the fabric). Bobbin tension is for the thread you see on the top of the fabric
Jul 01, 2009 | Juki MO-644D Mechanical Sewing Machine
Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Feb 01, 2008 | Sewing Machines
Singer Pixie Plus Sewing Machine Logo
180 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
