Question about Carrier Heating & Cooling
Carrier 58SS100-CC Gas furnace with 1010-919 control board. Where do the red and white wires from the outside AC unit attach to the control board? My unit was serviced this winter and these where not reattached.
  • 23 Answers
They should attache to the Y on the control board and C.
Posted on Jun 18, 2009
I have short in my 24v power line in my carrier ac/furnace
Hello, usually visuall inspection is the first thing I would do, may times the wires will short at the outside condensing unit or at the indoor control board. If you cannot see it visually then run a continuity test on the wires with a multimeter. To fix a short sometimes it is easiest to just run new wire.
May 04, 2012 | Carrier Heating & Cooling
I have a HoneywelI Enviracare Elite whole house humidifier. I have no power to the thermostat. The wire goes into the furnace and is attached to a control board. The furnace is working. Humidifer is n
Most of the humidifiers are run by 24 volts AC. disconnect the power wire to stat on circuit board and check there with meter and connect to low voltage ground for 24 volts, I'm assuming the two wires that power the humidistat are red and white.typically red is used for power. most likely you have power if the red for the stat is connected to the W on the board and the heat works, but the humidifier only works while heat is on.the next thing in line is the humidistat , it's a switch so if there is only two wires going to it take them off the stat and connect together, if furnace is on heat and running and stat wires are connected it will send power to water solenoid, if its not working yet the problem lies in the water solenoid if you have 24 volts at the two wires at solenoid.check while disconnected, do not connect those two wires together or a 3 amp fuse will blow on the furnace board. if you have 24 volts there then the valve may be bad or the valve may be stuck or clogged, loosen water supply line to make sure water is getting to valve. I spent many years working in the HVAC industry.
Dec 31, 2011 | Honeywell Humidifiers
I have Carrier 38TKB036 3 ton A/C condensing unit and one 28CCA036 3 ton A-coil to provide A/C to home thru existing furnice. A/C was on and stopped working. Turned off/on, but will not come on. Any...
Is the furnace fan (indoor fan ) running. If not the problem is with the inside unit. It supplies the control power to operate the entire system and has a control fuse on the circuit board. If it is running but not the outside unit then the problem is outside.
Aug 08, 2011 | Carrier 38CKC042 Air Conditioner
How do u wire athermostat to the furnance and ac unit on model e3eb-015h nordyne
You need to get low voltage wire known as 5 wire. run wires thru wall to stat and furnace Red wire goes to R terminal white to W terminal Green to G terminal Yellow to Y terminal on both the stat and furnace circuit board. Now you need a wire called 2 wire low voltage wire run that from furnace circuit board to outside A/C. At furnace hook red wire to Y terminal and white to C terminal doesnt matter which ones you hook up at outside unit. Do it just like i told you this will work properly.
If this helps please rate me.
May 20, 2011 | Heating & Cooling
My carrier furnace keeps blowing 3amp fuse when I turn thermostat to cool.
Hello, sounds like there is a short in the low voltage circuit. First inspect the wiring at the control board and make sure nothing is loose or touching metal. Also, inspect the wiring all the way to the outside unit and make sure it is not loose or touching metal on the outside unit. If you dont see anywires loose then you will need a meter to check the wires for continuity to the common terminal on the board with furnace and ac turned off.
Apr 23, 2011 | Heating & Cooling
Outside unit won't run
If the inside unit is running properly, there will be a yellow wire (or blue) from the thermostat down in the furnace that needs to be hooked up to the Y terminal also there is a red and white wire in the same place in the furnace coming from the outside unit, one goes to the Y terminal also and the other would go to the C terminal in the furnace. Otherwise you may have a bigger problem.
May 29, 2009 | Carrier 38BRC036 Air Conditioner
Does not find furnace
Make sure all wires are hooked correctly ABCD should match. The Kill all power try again. When Infinity control is hooked up correctly it by passes all dip switch so that it can communicate with the tsta furnace and outsid unit. Rus
Apr 30, 2009 | Heating & Cooling
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
Apr 28, 2009 | Heating & Cooling
Carrier Heating furnace
either the gas at the outside valve is off, or the gas valve at the furnace may be off, or the switch on top of the gas valve in the furace may be off. if they are all on, then you may not be getting a call for heat from the stat to the furnace control board. check to see if you are getting a 24 volt signal from the stat to the w terminal and common terminal on the furnace board. if you are then check to see if the voltage is arriving as 24 volts to the wires at the gas valve itself . if it is then the gas valve is possibly bad. if it is not then the board is possibly bad.look for loose or broken connections on the low voltage wiring. most unusual that the board does everything else but send power to the gas valve. you need to zero in on the valve i think and start by turning off power and that should restart the sequence of operation and you can observe it step by step . if you are not getting a call for heat then the stat may be bad be sure you are in heat , fan in auto and temp pushed up to max. if no 24 volts is sent to furnace board white and common low voltage board then stat is bad. remove it if you think its faulty and jumper the white and red wires together on the subbase. that duplicates what the stat normally does. if the furnace lights its the stat. having said that i realize the stat has to be sending a heat signal or the other stuff would'nt start. so..... back to the furnace board. check that 24 volts in from stat and 24 out to valve and that will put you on your problem item. good luck
Oct 30, 2008 | Carrier 38BRC048 Air Conditioner
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Heating & Cooling Logo
566 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
