Question about Avanti Model Shp1702ss - Superconductor Refrigerator
Avanti model#SHP 1702SS Superconductor fridge won't cool at all.Fans, light, switch,etc. work O.K.
Is the super conductor available as a part? Could the thermistor be the cause of the problem.The board supplies about 12.6 V. to the superconductor. the superconductor has a resistance reading.
5 Suggested Answers
SOURCE: Avanti 12 bottle wine cooler...switch
CHANGE THE CAPACITORS ON THE POWER SUPPLY (TO SAME VALUES) AND REMOVE THE JUMPER (CATODE OF THE BRIDGE TO THE CAPACITOR DOUBLE VOLTAGE)
Posted on Apr 16, 2009
  • 340 Answers
SOURCE: Avanti refrigerator not cooling
thermostat set ? might not be defrosting all the way. damper actuator not opening from freezer to refrigerator. is the condenser clean?
Posted on Jun 17, 2009
SOURCE: My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Posted on Feb 17, 2010
espressonist
  • 1711 Answers
SOURCE: avanti model wc412d....display reads "8"
The problem you describe is ruther expensive to be fixed so we beleive you should thing for a replacement you will give some more but you will have anew fridge.
Posted on Nov 23, 2010
Minha Ricoh SPC 430DN deu erro SC 563, podem me ajudar. Sou do Rio de Janeiro - Brazil
  • Code: 563
  • Description: Pressure roller overheat 3 (software error)
    The detected fusing roller temperature stays at 230°C or more for 1 second.
  • Causes: • Defective PSU • Defective BCU
  • Remedy: 1. Replace the pressure roller thermistor (center). 2. Replace the PSU. 3. Replace the BCU.
Ricoh Aficio SPC430DN Error Codes List page 11 from 17
Esto dice que es posible que el Photo Conductor Unit Copier Drum es malo o el Color Copier BCU Engine Control Board es malo.
Jan 26, 2018 | Ricoh Office Equipment & Supplies
Toshiba 2303A Coll for service C447
fuser related problem but try out this Check if the connectors are disconnected.
(2) Check if the center, side and edge thermistors are in contact with the surface of the fuser roller
properly?
(3) Check if the harnesses of the center, side and edge thermistors are open circuited.
2. Check the heater
(1) Check if the heater is broken.
(2) Check if the connector of the heater is disconnected.
(3) Check if the thermostat is blown.
3. Check the LGC board
(1) Check if the connectors CN308 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
4. Clear the status counter
After repairing the matter which caused the error [C410], perform the following:
(1) Turn ON the power while [0] and [8] are pressed simultaneously.
(2) Key in "400", then press [START].
(3) Change the current status counter value "1" or "2" to "0", then press [ENTER] or [INTERRUPT]
(to cancel [C410]).
(4) Turn the power OFF and then back ON. Make sure that the equipment enters the normal ready
Jan 21, 2018 | Toshiba Office Equipment & Supplies
Toshiba 255 photo copier..c410 error code what can i do for that
fuser related code
2. Check if the center, side and edge thermistors are in contact
with the surface of the fuser roller properly?
3. Check if the center, side and edge thermistors are not
deformed or dirty.
4. Check if the harnesses of the center, side and edge
2. Check the heater 1. Check if the heater is broken.
2. Check if the connector of the heater is disconnected.
3. Check if the harnesses are connected properly to the
terminals of the heater lamp.
4. Check if the thermostat is blown.
3. Check the LGC board 1. Check if the connectors CN308 are disconnected.
2. Check if the conductor pattern on the LGC board is short
3. Replace the LGC board.
4. Clear the status counter After repairing the matter which caused the error, perform the
following:
1. Turn ON the power while [0] and [8] are pressed
simultaneously.
2. Key in "2002", then press [START].
3. Change the current status counter value "1" or "2" to "0",
then press [OK] or [INTERRUPT] (to cancel the error).
4. Turn the power OFF and then back ON. Make sure that the
equipment enters the normal ready state.
Dec 01, 2017 | Toshiba Office Equipment & Supplies
How can I remove the cover from internal fan?
What is need for to remove cover .. Its safery from unknown access and accident. Kindly don't remove it
Apr 11, 2016 | Avanti SHP1700W 1.7 cu. ft. Compact...
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Semi conductor electric cooler
These people have a similar fan motor.
http://www.appliancepartspros.com/search.aspx?model=dts%20181%20cr%20dr%20ww
some semi conductor fridges use mains operated computer-type case fans.
Aug 06, 2015 | Furniture
C41 lock thish machine
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine. When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
(1) Check if the connectors CN316 are disconnected.
Feb 08, 2013 | Toshiba e-Studio163 Copier
Call for service c446
CN455/456).
Jan 29, 2013 | Toshiba E-studio 281c Copier
Error code C430
CN455/456).
Thanks
Jan 09, 2013 | Toshiba e-Studio 202L Copier
Fridge side ,freezer side not cooling at all
There are many noises a fridge can make. Fans may be working but not the compressor. If you can hear the compressor running then there may be a loss of coolant. If no compressor it could be: low coolant, bad thermostat, bad switch, bad timer...etc.
May 06, 2012 | GE Refrigerators
Avanti Model Shp1702ss - Superconductor Refrigerator Logo
70 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
