Question about Coleman Mach 15 Air Conditioner
Broken selector switch on Coleman TSR air conditioner
    New Friend:
  • 14 Answers
Check out my solution at this link:
http://www.fixya.com/support/t2513159-plastic_knobs_off_fan_speed_broken_need
Don't use pliers to turn the item or it will make it harder to fix when the post is mutilated to a pulp.
Posted on Jul 24, 2014
    Sergeant:
  • 340 Answers
You need a control if the center came out if it is just the plastic knob appliance parts store or google it. Tom
Posted on Jun 18, 2009
COLEMAN TSR FULL LOAD AMPS
Go to airxcel.com, you should get some options, to get either their literature or tech support and they should be able to help you.
Aug 07, 2012 | Coleman Mach 15 Air Conditioner
HOW OLD IS MY UNIT? IT'S A TSR MACH 3 WITH BLUE LETTERING THANKS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Feb 20, 2010 | Coleman Mach III Air Conditioner
Coleman AC compreser work but fan dont
If the selector switch is broken, you need to replace that first. This will cause the fan not to come on if there is an open in it. After replacing the switch, if you still have to fan operation, it is possible that you have a bad fan capacitor, part# 1499-5461, or a bad fan motor, part# 14683099. Replace the capacitor first before spending the money on a motor. An easy way to check is to see if you can start the fan motor by hand while turning it on a the selector switch. If the motor starts this way, replace the capacitor.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic 57915531 Air Conditioner
Coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Jun 28, 2009 | Coleman Mach 15 Air Conditioner
Coleman tsr rooftop airconditioner
NEED A FREON RECHARGE AND MAY POSSIBLY HAVE A FREON LEAK
STEVE'S APPLIANCE
516-300-3249
Apr 05, 2009 | Coleman Mach 15 Air Conditioner
What are the 1st 3 blower settings for?
Those are for the run time of the circulating fan after the heat has been satisfied.
Jan 26, 2009 | Coleman Mach 15 Air Conditioner
Tsr mach3 conditioner
The smell is because of the stuff growing inthe water from the air conditioner. When you run the a/c it keeps the water condensed on the coil. When you turn the a/c off and run just the fan, it allows the water to warm up and start evaporating thus allowing the goodies in the water to become airborn. It would be adviseable to have the unit disassembled and cleaned by a professional due to the obvious danger of mixing water and cleaning chemicals with electrical equipment
Jun 25, 2008 | Coleman Mach 15 Air Conditioner
Coleman TSR RV air conditioner
There should be a solar panel on top of your roof top air conditoner. There is a quick disonnect for the solar panel. If the monitor light illuminates the solar panel is working.
May 21, 2008 | Coleman Mach 15 Air Conditioner
Coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
482 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
