Question about HP Officejet 5610 All-In-One InkJet Printer
No Power to HP All-In-One 7310xi
It will not turn on. I tried different outlets, resetting (# & 6) while plugging in the power cord, replaced all of the surge protectors and even plugged directly into wall socket - still nothing.
  • Darial Jr Lasaria
    Darial Jr Lasaria May 11, 2010
    you need a tech. to check the power supply board it maybe the fuse or transistor damage.
  • 102 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab102
Posted on Jul 17, 2009
  • 71 Answers
Try to clean the ac adapter with a clean clothe on the metal part where you plug it on the printer. Be sure to unplug the AC adapter from the power outlet before doing this step. If the printer won't power ON, there is a possibility that the Power adapter or the printer is already faulty. Contact HP and they may replace it if it's still under warranty.
Posted on Jun 18, 2009
0xc18a0001 failure
You could try a power reset of the printer.
Press ON button to turn off printer
Unplug the power cord from the back of the printer
Remove all of the ink cartridges
Wait 3 minutes
Plug the power cord back into the printer
Press the ON button to turn on the printer
Install back all of the cartridges
If this does not work, you could try a hardware reset.
1) Press and hold LEFT ARROW and then press SETUP
Release both buttons
2) Press OK
3) Press & release RIGHT ARROW until LCD reads System Configuration Menu 2
4) Press OK
5) LCD reads Hardware Failure Status: Clear, Press OK to clear
6) Press OK, LCD now reads Cleared, Press Cancel to continue.
7) Press & release CANCEL until the Welcome or Ink System
Failure screen appears on LCD
8) DO NOT PRINT AT THIS STAGE
9) Use POWER button to turn OFF printer
10) Unplug power cord from electrical outlet and from back of printer
11) Wait 1 minute. plug power cord back into outlet first then back into the printer
12)Turn on the printer, Press OK
The printer will start to initiate, do not interrupt.
Dec 31, 2013 | HP Photosmart C6180 All-In-One InkJet...
Reset factory settings
Hi Harold,
Here is how to reset the HP Photosmart 8250:
Performing a full reset
1. Press the Power button ( ) to turn on the product.
2. With the product turned on, disconnect the power cord from back of the product.
3. Disconnect the power cord from the wall outlet.
4. Wait at least 15 seconds.
5. Connect the power cord into wall outlet.
6. Connect the power cord to the back of the product.
If the product does not turn on by itself, press Power button ( ) to turn it on.
Try to print.
Regards,
Sean
May 28, 2013 | HP - HP Photosmart 8250 printer
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
I cleared a paper jam in my hp officejet 7310xi/all-in-one and i'm still getting a carriage jam message. How can I get the printer back to normal?
Try to Reset your Printer.Before that search for any paper piece or any other obstacle which preventing carriage movement.
Full reset:
a. Unplug the power cable from printer when the printer is powered on.
b. Press and hold # and 6 while plugging in the power cord.
c. Wait until "Semi full reset" displays ("Semi" appears despite the fact this key sequence is defined as a full reset).
d. Answer questions - Language/country, etc.
Partial reset:
b. Press and hold # and 3 while plugging in the power cord.
c. Wait until "partial reset" displays.
I think it helps.
Jan 10, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Can not get hp 1210 to start -power is getting to machine but it will not start..
Solution one: Make sure the electrical outlet works
  1. Unplug the power cord from the electrical outlet.
  2. Plug another appliance into the electrical outlet to make sure the outlet works.
    • If the electrical outlet does not work , plug the product into another outlet that does work.
    • If the electrical outlet works, but the product still does not turn on , continue to the next step.
Solution two: Make sure the power supply is compatible with the HP product
  1. Make sure the voltage and amperage specifications printed on the power supply match the voltage and amperage specifications printed on the HP product. Voltage and amperage specifications printed on the power supply Voltage and amperage requirements printed on the HP product c01962881.gif c01962212.gif In this example, the voltage (+32 V) and the amperage (2000 mA) from the power supply is compatible with the voltage and amperage specified on the HP product.
  2. If the voltage and amperage specifications between the product and the power supply are compatible, make sure the connector on the power cord is the same shape and color as the connector on the HP product. WARNING: Do not force a power cord into an HP product that is incompatible with the HP product (different shape or size).
    • If the power cord is not compatible with the product, replace the power cord with a compatible cord. To buy a compatible cord, right-click the following link, How to Buy HP , and then click Open in New Window .
    • If the power cord is compatible with the product, but the products still does not turn on, continue to the next step.
Solution three: Reset the power module and test the power Step one: Reset the power module The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  1. Unplug the power supply from the rear of the product.
  2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
  3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. Reconnect the power cord to the power module.
  6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
  7. Check to see if the power module has an LED.
    • If the power module does not have an LED, continue to the next step.
    • If the power module has an LED, check to see if the LED lights up.
      • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
      • If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-One Follow these steps to test the power on the product.
  1. Reconnect the power supply to the rear of the product.
  2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
  • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
  • If the product does not turn on with the alternate power cord, continue to the next step.
Solution five: Service the HP productIf you have completed all the steps listed above and are still experiencing a problem, service t
Dec 01, 2010 | HP PSC 1210 All-In-One InkJet Printer
Front panel not responding
Please perform the following steps:
1. Unplug the power cord from the unit.
2. Press and hold OK and Cancel buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, please replace the unit. From my experience repairing coast HP OfficeJet 7310xi is almost equal to the coast of a new printer.
:) Dr Tony
Apr 19, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Totally lost power to HP 7110
Don't Worry the HP printer are deisgned to connect without the surg protector.
Try the steps mentioned bellow
Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
If This does not work in the power cord you will see a rectangle box like thing thats a apdptor, after plugging it to the power oulet for a couple of minitues, check and see if you can feel any heat in the adaptor if yes then the adaptor is good the power cord may be bad, so accordingly replce the power cord or adaptor:
For HP Parts check the link bellow:
http://partsurfer.hp.com/cgi-bin/spi/main
Good Luck
Oct 03, 2008 | HP OfficeJet 7110 All-In-One Thermal...
No power- no anything
Then check and see
Good Luck
Oct 02, 2008 | HP Officejet 5510 All-In-One Thermal...
Printer failed
Unplug the power cord from the All-In-One as well as the power outlet leave it unpluged for atleast 1Min time..
Then check and see if you are able to make a color/Black copy
Good Luck
Sep 30, 2008 | HP Photosmart C6100 All-In-One Printer
Error code 0xd05d010d reset power
Unplug the power cord from the All-In-One as well as the power outlet.
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
Good Luck
Sep 16, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
144 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
