Question about Blakeslee DD-60 Stand Mixer
Beater is stuck
Can't get beater out after making cookies.
  • Joanna Durrant Apr 14, 2014
    Vegetable in the shaft slot with the mixer upside down, waiting a moment, and then slowly working it down and out (another suggestion on here) is what finally did it!
  • 3 Answers
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Posted on Apr 14, 2014
Sunbeam beaters hitting each other
Check with Sunbeam. The beaters may have to be replaced.
Dec 11, 2013 | Cuisinart Food Mixers
Old classic Kitchen Aid (25+), new KA-TH beater bar and suddenly the bowl is getting knocked off the mount when making cookie dough. Is it the new beater, the base or something else?
Adjust the head height, with the motor raised look in where it hinges. There is a flat head screw there, anti clockwise a bit to raise the head up a bit and stop it banging about on the bowl. Just enough to stop it.
Oct 25, 2013 | Food Mixers
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Beater is stuck on the mixer. No leverage when I
Still stuck? It may need to be turn backwards by hand . poswsibly jammed on locking mechanism Try twisting it back and forth. . make sure to unplug.
Oct 26, 2009 | KitchenAid 32685 Mixer
Beater rubbing bottom of bowl
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Feb 14, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchenaid stopped working Modle KSM150PSER
Hi Phyllis. Unplug the mixer, lay it down on one side and look for the pin that holds the planetary shaft in place next to (where you attach beater). The pin may have worked itself loose. If this pin is not all the way through it's opening, the shaft will not turn the planetary unit. Hopefully the pin did not come all the way out and you can tap it back in. If the pin is gone, It's in one of your cookies and hopfully you'll find it before anybody else does. Hope this helps. Ricardok45.
Dec 17, 2008 | KitchenAid KSM150PS Artisan Series Stand...
My friend has a bravetti ep545
Call 1-800-798-7398 or go on-line to: www.euro-pro.com for replacement parts for the Bravetti EP545 hand mixer.
Dec 20, 2007 | Bravetti EP552H Hand Mixer
Motor runs but the beater does not move
you most likely stripped the plastic gear (Worm gear???).  This gear is designed to fail to prevent the motor from burning out under EXTREME loads (i.e. when a metal piece falls into the bowl). The plastic gear is much cheaper than a new motor.  Look around on this site to see how to get at/repair the gear.  I've found many parts on eBay.com and also PartSelect.com.
Dec 16, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Can't attach beater to kitchen aid
good day,
hope this link below will solve your problem.
kitchen
Dec 13, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
Just get clicking sound . . . beaters don't move
you snapped one of the drive gears. Your gonna have to get someone whos mechanicly inclined to take apart the drive motor assy and see whats broke. You should be able to get the parts at http://www.repairclinic.com good luck
Jul 15, 2006 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Food Mixers Logo
401 people viewed this question
Top Blakeslee Food Mixers Experts
eyecam
Are you a Blakeslee Food Mixer Expert? Answer questions, earn points and help others
