Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
My Toyo Laser 30 has an error code EE 5 and I can't find any info on that particular code. Help?
Error code reads EE 5 and the power button won't turn it off, the reset button does nothing, and unplugging / re- plugging it in does nothing.... Still EE 5
  • 42 Answers
Call manufacturer or Installer - Direct Vent Furnaces are not a DIY service. Carbon Monoxide is deadly and can easily be emitted if there is something wrong with the heater. Get professional help before anything further is done, as it needs a full inspection for your safety.
Posted on Jul 06, 2014
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Posted on Nov 10, 2007
Pnutgllry
  • 57 Answers
SOURCE: toyostove laser 30
Could it have to do with the temperature sensor? If it is still coiled up on the back of your heater, it may be turning the heater off. You need to uncoil the sensor wire, and place the sensor somewhere away from the heater. One sight said atleast 8" off the ground. (I have a Laser 73 and mine is about two feet to the right and about 8 foot up on my wall as I have a lot.) You can attach it to a board if you have to, or any other item. Just put it as far away from the heat of the heater as you can so it will only be sensing the room air temp. If the line needs to be longer you can cut in stereo wire (I read this online too). Then play with the heat settings to see at what temp it is most comfortable for you. Hope this solves the problem.
Posted on Jan 05, 2009
  • 674 Answers
SOURCE: i let my tank empty
You may have an air bubble in the fuel line or the filter (if you have one at the fuel barrel) may be clogged. The filter has a vent screw on top and you may need to vent the filter to get the fuel flowing. There is also a strainer in the fuel sump that may have gotten clogged.
Another thing is to push the red float reset button on the right side of the heater. If the float is latched up you will feel a little resistance and hear the float drop. Only press the reset button momentarily. It is not a primer button.
You can get a bowl and some rags to set under the line where it connects to the back of the heater and then loosen the line to make sure you are getting kerosene to the heater.
The fuel pump makes a loud ticking or thumping sound if it isn't getting any fuel.
Let me know if this helps or you need more advice.
Posted on Nov 20, 2010
  • 674 Answers
SOURCE: i let my tank empty before refueling and now my
You should check the filter at your oil barrel if you have one there and loosen the small vent screw to bleed the filter and line. You can also check the strainer in the fuel sump but remember to turn off the fuel at the barrel before removing the strainer from the sump. Also press the float reset button on the full sump. You can loosen but not remove the fuel line on the back of the heater if needed to get the fuel flowing. Be sure to place something under it to catch the kerosene and have some rags handy.
Posted on Jan 03, 2011
My Laser 30 went into power saver mode by itself and now I can't get it out of said mode, otherwise it's working well.
Rick,
Sorry to hear you're having issues with your Toyo, first off do you have a manual for your stove? If not, you can download one online, I've included the link for your convenience.
Your Toyo has a series of control buttons across the top and/or the front, the "On/Off" button for the "Power Saver Mode" is located in the middle. You can turn the mode On or Off, though you actually WANT to utilize the Power Saver Mode. It's intended to prevent unnecessary ignitions on the stove, thereby lowering your electrical consumption as well as wear & tear on the stove. All you need to do is set a maximum and a minimum temperature and whenever the temperature is not within the parameters you've established the stove will then either ignite to heat the area to your pre--determined setting or shut off until the temperature is within the parameters you've established. If there is NO error code(s) showing, and the stove is running fine, then I would not be concerned. Though I do suggest you immediately download the manual, read it thoroughly, and when necessary use it to troubleshoot future issues.
I hope this helps you, good luck and stay warm!
Regards,
Shekele
North Pole, Alaska http://www.toyotomiusa.com/OwnersManuals/Vented%20Heaters/Name%20begins%20with%20Laser/Laser%2030%20(Type%20D).pdf
Oct 09, 2014 | Rinnai Toyostove Direct Vent Heater: Laser...
I have an error code of EE2. The system will not
First- do you have enough fuel.
Does the unit ignite or not
More info would help me
Total Toyo
(907) 488-9179
Dec 15, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo Stove Laser 30 will not work
The EE-8 indication means there is insufficient air flow to the combustion pot to atomize and ignite the fuel. Check your air switch for a closed condition when the blower is operating.
Oct 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo stove laser 30
EE22 means that your Toyo failed to ignite 3 times in a row. You need to unplug it for 30 minutes to reset the circuit board. Then plug it back in, push the red reset button on the right hand side in the little hole towards the back and push the Power button. Your Toyo should ignite after that barring some other problem caused by running out of fuel.
I am assuming that you ran out of fuel which caused the EE2 error code originally. Sometimes, when you run out of fuel you can get water, ice, debris in the fuel line causing an obstruction or limited fuel flow. You may also get an air lock. You may need to crack the fuel line at the back of the Toyo where there is 3/4 nut and bleed the line. If you see no fuel or a small quantity of fuel then you will need to thaw and/or purge the fuel line in order to get fuel to your Toyo's fuel pump.There is also a screen in the sump which can get plugged with rust, debris from the bottom of the fuel tank so you may need to clean the screen in order to get fuel to the pump.
Nov 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Heater - error message "12"
An error code of 12 on your heater means a flame failure has occured. It could be the following: Flame Rod dirty, Obstruction in burner, improper gas pressure, or a bad ignitor board. I am suggesting you get a technician who is familiar with Rinnai products to check out the above items.
May 25, 2008 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Ee 12 code
Hi alaskasteve,
My business is Laser Heating Service in the North Pole/Fairbanks area of Alaska. EE12 is the error code for overheating. Most likely you have a Laser 30 giving you this error code. The most common reason for the EE12 error code is that the Toyo is not getting enough air circulation across the heat exchanger and causing it to overheat. Look at the back of your Toyo where the black frame around the circulating fan and flue pipe is. You will see a screen that slides in a slot at the back of the Toyo. Slide the screen out and clean it. If you have a smoker or the Toyo is in a kitchen area where it collects nicotine or grease then you may need to clean it with hot water, detergent, or 409 Cleaner to get the sticky residue off that the dust fuzz collects on and clog your screen. EE12 can be caused by a couple other issues, but they are more rare. Try this first and let me know if it works! toyotechnician
Jan 15, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo 3
What Does EE2 Mean? Laser 30, 56, and 73 model Laser heaters cease operation and display
the EE2 code on the control panel (instead of the clock or temperature settings) when the primary
flame rod on the heater fails to sense a flame during the first 5 minutes of the Ignition and Pre-
Heat cycle. On the Laser 55 and 72 the heater will stop and the red Reset lamp will light rather
than the EE2 code. (Note: There may be other reasons for the reset lamp to come on but much of
this information will apply.)
What Can Cause An EE2 Error? The primary flame rod is the only sensor in the heater that
can cause the EE2 error. Thus, if it occurs, either there is (1) no flame to detect, or (2) the
sensor failed to detect the flame. The flame rod is located on the lower 1/3 of the burner. It is a
heavy wire with a ceramic insulator. A single white insulated wire connects this device to the
main circuit board.
Dec 12, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Oct 20, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
197 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
