Whirlpool AWO/D 42420 has no power, no lights
I checked the socket/power source, it works with other appliances. I changed the fuse for one that works. Still nothing, no lights, no response. What can I do? This comes just a few days after our TV died in a similar way. One minute we were watching it, then it just switched off. No lights, no power. Also checked the power source and the fuses. So I have 2 questions: 1) what can I do with the washing machine? 2) does this sound like a problem with the wiring of the house, causing appliances to blow?
  • 1462 Answers
SOURCE: zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
Posted on May 16, 2007
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
SOURCE: LG WASHING MACHINE WM14225FD
My machine would not switch on this morning, no beeps or lights, I traced it to a small fuse on the main circuit board. you get to the board by disconecting from the mains, removing 2 crosshead screws at the back of the machine and lifting the top of the machine off ( once screws out, slide top of machine back about 1cm and then it just lifts off. You can now see the main circuit board, behind the control panel on front of machine. the fuse is hard to see and is solderd to the board on the lower left side, I solderd onto both ends of the fuseand replaced with a 10 amp HRC fuse, I still need to find the correct fuse rating, this worked for my machine.
However, and its a big however, If the 13amp fuse in youre plug blew and the trip on youre consumer unit, then I would imagine something big (pulling a large current) has gone down in youre machine to cause all these to blow, anyway hope this helps, Robin.
Posted on Dec 05, 2008
  • 53 Answers
SOURCE: Candy GO1482 washing machine blows house fuse
This sounds like an electrical fault within your Candy washing machine.
Have you tried plugging your coffee machine, dishwasher or toaster into the SAME POWER SOCKET?
If so, does this still trip out the mains/house fuse?
If it does, it sounds like there is a fault in your house wiring.
If these "high power" devices/appliances do not cause the same problem, then you may have an Earth Leakage fault on your washing machine or something else inside it has short-circuited and will need servicing right away!
Posted on Nov 18, 2009
SOURCE: Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Kolbrun
Posted on Feb 22, 2012
Hi,My whirlpool AWO/D 8140 appears dead there is power going to the machine but there are no lights on. Is this fixable
probably the circuitboard. you should call a household technician to check the machine and if not i'm afraid it will need to be replaced
Aug 13, 2017 | Whirlpool Washing Machines
AWO/D4405 whirlpool washing machine has power to machine but nothing lights up or works ?
all washers have a switch without them the washer would cease to operate. Check power source (outlet at the wall. ) use bed light lamp to test. if thats ok you may have a a faulty switch or an internal safety fuse blown
Jan 31, 2015 | Whirlpool Washing Machines
MY WHIRLPOOL WASHING MACHINE AWO/R5206 CONTROLS ARE NOT LIGHTING UP AT ALL. CHECKED FUSE IN PLUG AND FUSE BOARD NOTHING WRONG.
I am sure there is a electronic control board on the machine. I will bet the control board is defective.
Nov 26, 2014 | Whirlpool Washing Machines
I have a whirlpool awo/d8140 washing machine that has suddenly seems no power. I have changed the fuse tested the plug and socket and nothing apears untoward when taken the lid off. Any ideas? Cheers Neil
If there is power to the main board, would suspect the board is the issue, however, if the pump, motor , water solenoid ect has a fault, machine will not fire up
Nov 22, 2014 | Washing Machines
No power to Whirlpool awo/d5727. I have checked the fuse and the socket but still have no power.
You say you checked "socket" and the "fuse," did you mean the AC wall outlet (115V) and a fuse or breaker in the main power panel?
Nearly all circuits involving water are protected by a Ground Fault Interrupter that can be servicing several wall outlets (perhaps one not near the washing machine) or can be located as part of a circuit breaker in your main power panel.
The GFI outlets will have one or two push buttons located between the outlets and a combination GFI/overcurrent breaker will also have at least one button where others will have none.
If you find one that is tripped, try resetting it. If it will not reset, unplug the washing machine and try again.
If it now stays on, your machine may have an electrical path causing it to trip and using an unprotected outlet may be unsafe and an indication that the appliance itself may have electrical leakage which could be otherwise dangerous.
The circuit breakers in the main power panel can also fail (they didn't 20 years ago) and we have replaced 3 in a home only 5 years old already so they are not made well anymore.
Jun 22, 2013 | Whirlpool Washing Machines
Whirlpool AWO 10781 door locked light flashing
Hello
Unplug the device from AC mains socket, and replug it after 10 minutes and check. If it does not help you, the machine has to be troubleshooted. Its internal memeory circuit [electronic] has the fault.
Feb 01, 2012 | Whirlpool Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
No heat on Whirlpool leq8000jq1. Is it just the heating element?
There are several things that could cause this problem, here are a few common things it could be, before doing any checks you should always make sure you disconnect your appliance from it's power source.
  1. bad heating element, you can check the heating element for continuity with an ohm meter.
  2. bad thermal fuse
  3. faulty power cord
  4. bad thermostat
  5. tripped breaker or blown fuse from house power supply, check to see if you have 240 volt supply to your appliance.
Mar 15, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
