Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
My saltwater pump will not come on at all. It ran a full 12 hour cycle last night. Any suggestions?
After you run it for a cycle, the chlorinater will automatically come on at the same time the next day. If you want to run it before then, you need to turn it off and back on again to reset it. You may even have to unplug it and plug it back in. Good luck!
Posted on Jun 21, 2009
Water is greenish brown
run run run that pump 24/7 clean clean that filter check ph first then balance other chems it will take awhile with well water to clear
Jul 14, 2017 | Intex Automatic Salt Water System for ...
I just put up an 18x52 Intex ultra frame pool last week, The saltwater pump and filter pump have both been ran daily for 12 hours.. No codes from the saltwater system, and the water is crystal clear.. ...
I sometimes have the same issue with mine.. One thing missing that helps protect the chlorine from burning off in the heavy sun is (Cyanuric Acid)or (CYA) You should be around 30-50ppm.. To bring this level up to 30-50, they sell a conditioner that raises this level.. Don't add too much if your already close to the 30-50ppm.. Other than that, you can continue to run the system as you already do.. Seems like it's maintaining clean and clear... Hope this helps???
Aug 31, 2011 | Intex Automatic Salt Water System for ...
My pool water has turned green in 2 days. I have an Intex pool with a saltwater system. How do I get it back to normal? I am new to the pool thing so you may need to put the awnser in laymans terms.
As long as you have the correct amount of salt and the electrolytic cell (The thing that makes the chlorine) , run the pump at 12 hrs with the chlorinatior at 10 to 11 hrs in between those 12 hrs for one full week and you will see results. Also, vacuum and clean your pool now before you start the 12 hrs cycles.
Jul 22, 2011 | Intex Automatic Salt Water System for ...
Recently installed Intex saltwater system, all of a sudden, have green forming around walls of pool. All levels look okay; except chlorine is a little low and PH is very high...I ran the boost cycle last...
Once you get the "Green" stuff on the walls, you must brush it off.. and one boost cycle will not do.... Make sure you have the correct salt level!!! Keep in mind..big pools can take up to 350 lbs of salt... Now...set you pump at 12 hrs and you chlorinator at 10 hrs between those 12 hrs.. Run this cycle and you should see results within 2 to 3 days... Clean you filter and rinse your electrolytic cell after 3 days because you will have dead algae. After the water turns clear, you can then lower your cycle to 10 pump and 8 chlorinate.. Good luck! hope this helps!
Jul 19, 2011 | Intex Automatic Salt Water System for ...
What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
Jul 18, 2011 | Intex Automatic Salt Water System for ...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
Hi, last month we bought an intex round pool (18' x 54") with sand pump and salt sanitizer. Within the last 2 days the water started turning green. It turns out my husband accidently set the pump...
You don't want to swim in water that has algae... 1st ...Make sure you have the correct amount of salt. See you manual for amount needed. Must set you pump timer first and sync your chlorinator between that time, if pump turns off before chlorinator cycle ends, you will get an "Low flow" alarm. Set you pump timer to run 12 hours and the chlorinator for 10 to 11 of those hours and should see results within 3 days or so. After that, If you live in an area that is hot, 10 hours pump and 8 to 9 chlorinator... Hope this helps...
Jul 13, 2011 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
May 30, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
211 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
