Question about Philips GOGEAR SA6045 MP3 Player
Headphone audio jack
The audio jack is loose or can this be replaced
  • Philips Master
  • 3,320 Answers
Try some crazy glue
Posted on Apr 14, 2014
Loose audio plug
thing is headphone jack seems gone unable to fix that try to buy new headphone or else try to use the port at the backside of cpu.
Feb 16, 2014 | HP Pavilion Computers & Internet
Headphone jack does not work
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC. The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa. The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound. Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel. Double-click "Headphones." If no "Headphones" option is available, double-click "Speakers." Click "Properties" on the General tab. Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable. Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab. Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume. Go to the "Enhancements" tab. Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device." Click "OK" to close Headphones Properties or Speakers Properties. Test the audio. If the headphones fail to output sound, unplug the headphones from the computer. Reconnect the headphones to the PC. Headphone jacks are color-coded lime green on most PCs. Look for the headphones symbol if the jacks are not color-coded. Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa. Test the headphones. If headphones still won't emit sound, the sound card most likely requires replacement. b> Replacing the Sound Card b> Shut down the computer. Remove the power cord from the back of the PC. Disconnect the keyboard, mouse, monitor and all other peripheral devices. Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD. Set the computer on its side. Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer. If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed. Remove the new audio card from its protective packaging. Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks. Screw the card to the computer case. Reassemble the computer. Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer. Plug the headphones into the new line-out jack. Hope this helps.
Jan 21, 2013 | Acer Aspire Computers & Internet
I have an Acer Aspire Notebook. When I plug headphones into the audio jack there is no sound, however, the sound works fine from the notebook speakers. Can anyone help me?
Hi, May I know if have tried alternate headphones and if they are the same?Does the headphone work when wiggled within the port if yes then the issue is with the headphone jack being loose and you would need to send the computer for a repair if covered by the manufacturers warranty as the headphone jack needs to be replaced. Thank you for your time.
Nov 23, 2010 | Acer Aspire One A150-1006 Notebook
My nuvi 760 doesn't play sounds anymore - through the speaker or through the earphone jack. I deleted some mp3 files a while back and I wonder if I accidentaly delted a audio driver file. I'd like to check...
No, there ar no audio drivers. If you use the headphone jack a lot, it coul dbe that the headphone jack has broken loose from the board. The headphone jack also controls audio to the speaker. The headphone jack must either be resoldered to the board or replaced. Please see this link:
http://www.sharc.net/gps_audio_repair.htm
- Jim
May 20, 2010 | Garmin Nuvi 660 GPS Receiver
My sony 771 won t play any sound -- not the speakers because doesn't come through headphones either. Just cleaned the lens for CDs last night, then this problem developed. Can see the amp bars moving, so...
The lit indication ("amp bars") proves that the aduio signal is getting through the unit's circuitry @ least to that point; lack of sound @ the spkr & headphones indicates the amplifier portion of the circuitry is either inoperative or disconnected from the load (i.e., either the speakers, or the headphones). A common cause of this type of problem cropping up unexpectedly is the headphone jack itself; in most products of this type, the audio path from the amplifier output to the speaker connection runs through the headphone jack, so the the speakers may be "turned off" when the headphones' plug is inserted into the jack. If the unit's owner uses headphones regularly, the most common problem to be found with the jack is loose solder connections to the printed circuit board's traces from the jacks' lead(s); in units with this problem whose owner's irregularly use the headphones, it's more common to find oxidization of the electrical contacts within the jack itself.
Dec 10, 2009 | Sony Audio Players & Recorders
Can't get my laptop speakers to work through headphone jack
the reason for this is that the audio thru this jack is attenuated to a level where you don't loose quality and to prevent ear damage. You better try the audio out or audio monitor output jacks located in the back of the tv(if this model comes with them). you'll probably need an audio amp to get the speakers to work properly though.
Sep 09, 2009 | Insignia LCDTV26 26 in. Television
Toshiba A10 headphone jack problem
I think you are on the right track, if the headphone jack is worn and shorting out itll kill the speakers because it thinks headphones are plgged in, ebay would be a good start for parts, maybe even call toshiba and speak to their tech support.
Dec 13, 2008 | Toshiba Satelite A10 Notebook
Sound Problem with Headphone
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
Nano shows song playing but nothing happens
Make sure your headphones are working properly by testing with your computer headphone jack.
Is the headphone port on the Nano loose?
Connect the Nano to your iPod dock and see if you can head audio through the docks headphone jack.
If the headphones work, and you can get audio out of the dock headphone port, then there is a problem with your Nanos headphone jack.
Apr 07, 2008 | Apple iPod nano 3rd Generation
Philips GOGEAR SA6045 MP3 Player Logo
55 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
