Question about Cassida Corporation Cassida C200 Coin
No power my cassida c200 was working one day and the next i cant get iT TO POWER UP
The display on my Cassida 5510 currency counter does not light up when the machine is powered up. How do I proceed?
Hello Wayne,
There is basically only 2 things that can be checked before having the unit serviced.
1. Check that the AC outlet that the power supply is plugged in to is working (110vac).
2. Check that there is 24vdc coming out out of the power supply with a meter.
If both are good then the only option is to have the unit repaired or replaced.
Good Luck!
Rich Lilja
Jul 24, 2016 | Office Equipment & Supplies
ERROR E38
Found manual here with all error codes. It's in Russian though..
http://www.rservice.by/files/manual/cassida/counters/Cassida%20Billcon%20N120%20User%20Manual%2028.11.2013.pdf
Mar 24, 2014 | Billcon N-131 Money Counter
C100 Coin Sorter & Counter C-100
Coin sorters have to be able to handle a variety of coins in a variety of conditions. The one intended for home use are not very accurate even when new and sorting accuracy declines with age. The only practical "fix" is to take a technological step backward and sort coins manually.
Nov 12, 2013 | Cassida C100 Coin Sorter & Counter C-100
MY WEBCAM IS NOT WORKING ON MSN OR SKYPE
Try the free webcam test tool and select the C200 from the drop down list. If you can see yourself the webcam is working, if not you will need to reload the driver software. If it is working launch Skype, and go to Settings, Camera to select the C200 and it should work. To select webcams in MSN click Tools, Audio & Video set up, Next. It should give you the option to choose what camera you want to use.
May 09, 2010 | Logitech WEBCAM C200
Audio Driver Lenovo 3000 c200, does anyone have it?
Try this.
http://www-307.ibm.com/pc/support/site.wss/MIGR-66525.html
if this does not work, try installing modem first then restart.
vote if this helps.. thanks.
Mar 27, 2009 | Lenovo 3000 C200 Notebook
Is it possible to repair c200 power supply
Fujitsu C200 has very precise power supply. And it is always recommended to buy new one.
Jan 27, 2009 | Fujitsu Siemens PRIMERGY C200 Server
Daughter Laptop...says Error USB over current hc/port.. is a Lenove model 0768.. any ideals?? Thanks
Normally that means that she has connected possibly something into a port or 2 that exceeds the limit the windows defines. You cant change this limit however if she was to put it into a different port or to remove one of the devices that does not have its own power supply it will work again. Only thing its saying is that you have too many objects in the port that require power from those ports. In other words... It cant supply enough power to the things plugged into the usb hub [2 usb ports(usually by each other)]
Dec 17, 2008 | Lenovo 3000 C200 Notebook
Getting playlist to cooperate
Check the firmware upgrade for the c200 series on Sandisk's website (and the forums) - I can't remember exactly how it goes, but either the firmware upgrade makes playlists display correctly, or it prevents them from dispalying correctly - I can't remember which
Jun 30, 2008 | SanDisk Sansa c200 MP3 Player
Nipple mouse button
More than likely you will have to replace the whole keyboard. These do go out in time.
Jun 18, 2008 | Acer Tablets & eReaders
Have power but no disply hard drive not working
http://www.passwordmethod.com/content/view/108/27/
Try here. A last resort to IBM Problems.
Mar 22, 2008 | Lenovo 3000 C200 Notebook
Cassida Corporation Cassida C200 Coin Logo
149 people viewed this question
Top Cassida Corporation Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Cassida Corporation Retail Supply Expert? Answer questions, earn points and help others
