Question about Husqvarna 362 365 371 372 385 570 575 576 Chain Adjuster Tensioner Assembly
Huskvarna 365 It will idle but when you give it throttle it will backfire
    Guru:
  • 145 Answers
Out of the carb (FIRE HAZARD) or exhaust (FIRE HAZARD)?
Posted on Apr 14, 2014
Why does my Vintage Cub Cadet 125, Kohler 12HP engine pop/backfire and die when given any throttle?
Carburetor needs adjusted. May need rebuilt or just cleaned. Could be one of the jets is plugged.
Jul 19, 2014 | Cub Cadet Garden
Backfireing when ideling and when i give it some throttle
CHECK PISTON RINGS FOR WEAR AND I WOULD RE CHECK THAT CARB ADJUST IDLE SPEED JET ETC. WORSE ADJUST VALVES.
Jun 30, 2013 | 2003 Yamaha V Star 1100 Classic
I have a 1985 vt1100 c Honda shadow. It recently started idaling high by its self.I then removed tank and adjusted the idle and was fine for about 3 rides.Then it started idaling very low to actually...
Might be a throttle cable sticking. I would disconnect, from the throttle and drop some synthetic oil down the cable after finding some way to straighten it up and allow the oil to flow through the cable. It is an overnight operation and might actually take several applications.
As for the backfiring, I would question if you have carbs or fuel injections. If the later, you might be leaving your throttle open slightly and giving the bike fuel which pops off while changing gears.
Jul 20, 2017 | Motorcycles
Husqvarna 365 backfireing
Check your spark plug for 'whiskering' (tiny strands of carbon collecting across electrodes) and clean and re-gap. If this not the problem, check carburettor fixing to engine - may be drawing air through failed sealing gasket. Good luck!
Jun 09, 2012 | Husqvarna 362 365 371 372 385 570 575 576...
Dodge dakota, rough idle, backfires, dies under throttle
My 93 Dodge Dakota 3.9 4WD just started doing the exact same thing. Any solution yet?
Jun 02, 2009 | 1994 Dodge Dakota Club Cab
try a vacuum gauge and see if it reads what it suppose to you might have a vacuum leak
May 20, 2009 | 1994 Dodge Dakota Club Cab
Backfire out of carb!
Remove and clean the carbs. Clean the air filter and install new stock plugs. Re-mount the carbs and then balance and sync them. Now would also be a good time for a compression check. Valves and rings do give problems sometimes but these problems show up first as a lack of power. Since you didn't report a power problem I doubt if valves are the problem.
Mar 26, 2009 | 2001 Harley Davidson FLHTCUI Electra Glide...
Husqvarna 362 365 371 372 385 570 575 576 Chain Adjuster Tensioner Assembly Logo
118 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
