Question about Garmin GPSMAP 421 GPS Receiver
Power I have a gps421 I purchased about 2 years ago. I used it 3 or4 times and it worked well. I had some issues with the cord fitting on the 421 but was able to power up n use. Last year 2013 I could not power it up and just put it away. I have been unable to power it up n don't know why. I connect to charged battery but it won't power up. My guess is the power cord just because it seems difficult to connect. I checked the fuse n it seems fine. Any ideas
  • Garmin Master
  • 3,904 Answers
I would locate the actual power supply that is supposed to be with it and try that. Using the wrong one has either ruined the connection point or fried the unit.
Posted on Apr 14, 2014
SOURCE: Garmin C340 battery not charging
The Garmin batteries tend to die after about 2 years. Garmin will replace the battery for you but prepare to pay top dollar. It is a shame because the problem is commonplace. They should have made the replacement user friendly. The battery is buried deep inside and it is soldered.
Posted on Jul 13, 2008
cd_droptop
SOURCE: garmin fishfinder 160 blue . no powerup
I have a 160 blue also, and this morning I had the same problem. I called tech support while I was out on the water but no help. When I got home I double checked my connections on the battery minder/selector and the fuse panel. My GPS worked fine but the FF only beeped, like it had low power and the display wouldnt come up. It came up once for about a second and then faded earlier on the water. I pulled the power and ground connections from the fuse block and put them directly on the battery, it came right up. I now run the FF wired straight to the single battery and the GPS and other items on my other battery.
Hope it helps.
1998 19' Proline Center Console
"Lucky in Love"
CD
Posted on May 01, 2009
SOURCE: My Garmin 255w will not power up. Can this device be fixed?
Do a soft reset by pushing the power switch to the left and hold it there for 10 to 15 seconds. The unit should turn on.
Posted on Jun 22, 2009
bestdarngood
  • 3037 Answers
SOURCE: My Garmin 305 has stopped working. It is 1 1/2
If it won't start, try connecting it to your computer and see if you can get a firmware update to turn it on. Otherwise I would send it into garmin since there aren't replaceable parts for consumers.
Benjamin
Posted on Jul 17, 2009
  • 1584 Answers
SOURCE: garmin 178c turns off on it's own.
Hi
Sounds very much like the wiring plug connections in the back, always overlooked but so important that connections are tight and contacting.
Posted on Aug 13, 2009
Samsung galaxy gt i9003
tryed new firmware? official or not
May 20, 2013 | Cell Phones
My Life Fitness Display is completely dead, worked fine the last time it was used 2 weeks ago
11_22_2011_12_21_49_am.gifAdjust for 1/8" and clean the sensor switch. Remember the main boar controller motor control the function for the display board(by power supply, electronic signals like the sensor reed, etc) Tight the flexible cable or ribbon cable and plug with carefully and paciencie, Disconnect the power cord
Oct 22, 2011 | Life Fitness 9100 Next Generation...
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
Mar 21, 2011 | Vizio VOJ320F1A 32 in. LCD TV
I have a vector lite but have lost the recharging cord. Where can I purchase a recharging cord for my vector lite? Thanks Steve
use an extension cord - I found a cheap, old, brown one the fits just right. also.... i purchased a Y extender for a grounded plug, online years ago.... turns out it fits on that plug just right ... Y plug is a grounded male plug that plugs into an outlet..and, on the opposite ends are 2 grounded female inlets, and one fits on the spotlite nicely... but, the extension cord, a cheap one from a local drug store, should work... take it with you, late at nite, and trry it out on the plugs... let the clerk know what you are doin, then they won't be watching the heck out of you.
you'd be surprised, you probably had something laying around the house that'd work just fine...
now, I need to replace my battery but, I cannot identify which 1000 I have, if there are different model numbers... all the writing has come off except the "V" and the "1million" ... but, ultimately, I need to find a battery for this baby - thoughts?????
d
Dec 28, 2010 | Vector 1 Million Rechargeable Spotlight
Please advise if your Black & Decker Weed Thrasher model # ST4500, has been recalled? I purchased mine less than a year ago and used it now approximately 12 times and it is dead, no power? I have...
Black & Decker warranties all of their products for at least 1 year, and some of their units for 2 years. Go to http://www.blackanddecker.com/Service-Centers.aspx to find your nearest authorized repair facility. Do not return it to the store you bought it from.
Good luck
Dec 03, 2010 | Weed Thrasher For Gas Grass Trimmer Wacker...
No power, dead completly..does it have a fuse or anything that I can reset?
Not that I know of. Are you sure that the power cable you are using is the right one for the printer? Just because it fits the connection on the printer does not always mean its the right cord.
Check the power ratings on the back of the printer and compare them with the ones listed on the cord. Do they match? If so, does the cord fit the back of the printer snugly without wiggle room?
Have you tried other outlets to make sure there is no issue with the one your using now?
The power supply in HP printers usually lasts a lifetime. I doubt that this could be your problem.
When this has happened to me in the past, the problem has always been the power cord I was trying to use. Some power cords have fuses in them that can be bad. Is your cord a two piece with a box? Or a single piece cord? If its a single piece cord, I would question that it is the right one meant for the unit?
If its a two piece cord, make sure the voltage is right for the machine and follow the cord from end to end to make sure there are no other issues causing a power connection problem. Plug it into the printer and see if there is "play" when connected to make sure that it has not been stretched out and fits where it is supposed to go correctly.
If its the right cord and the connection is snug ect., and it still does not power on I would suspect that the power cord itself has gone bad for one reason or another. There was a type of cord that was issued with certain models of HP printers that was recalled due to malfunctions causing over heating a few years ago. I have not heard of any current issues, but you never know. Try replacing the cord and see if the unit powers up. If it does not then it will be a first and the issue your having is out of my expertise. (I am in my last year of school for my bachelors degree in Computer networking and have about 10 years experience in this field. This should help you gauge my advice)
Sep 27, 2010 | HP PhotoSmart 1115 InkJet Printer
My red light is flashing, I have changed cartridges, although it was not time. What can I do now. I just purchased this 5 months ago.
you may try to reseat the Ink cartridges for 2x's if this flashing redligght still flashing. YOu may also try to reseat the printhead of your printer.
Now if the troubleshooting will not solve the issue, since you just replace the cartridges there might be a problem on the printhead itself., You need to call kodak for printhead replacement toll free 1 800 421 6699 ext 05.
Your printer will not work if you have an error or flashing red.
Nov 13, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
The TV will not power on with remote or manual button
Have you had any major power outages in the days leading up to this issue? It could be a power source, cable or outlet. Try different outlets if you can and see the tv responds.
Best of luck,
Al
Apr 18, 2017 | Cyberhome CH-LCTV 150 15 in. LCD...
Dell 600m Laptop Killing batteries
If you are using known good batteries, and you have the most current BIOS Flash, then it is likely a failure of the charging curcuit on the motherboard. The flashing Amber (Some people see it as red) led indicates a failed battery
The Multiple good batteries, I assume have been recently purchased, because computer batteries are consumable and are rated for 300 to 500 charging cycles before they wear out.
I replaced my 700m motherboard with one from Ebay for about $170.00 about a year ago.
Jul 05, 2008 | Dell Inspiron 600M Notebook
Garmin GPSMAP 421 GPS Receiver Logo
18 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
