Question about Garden
20 inch lawn mowers. Looking to use a 148cc, vertical shaft engine in a kart. Any suggestions on a transmission?
    Guru:
  • 145 Answers
You could use small hydraulic pump and a hydraulic motor (same things) pretty expensive for good ones, and hoses clamps fittings etc Google images NO GAINS IN HORSE POWER NO LOSSES EITHER JUST TRANSFERES AVAILABLE HP
Posted on Apr 14, 2014
SOURCE: Lawn mower
Definitely do Not use these oils in your engine! Any good motor oil of the right viscosity will work, such as 10/30 or 10/40.
Posted on Sep 10, 2008
  • 166 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Posted on Jun 16, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
  • 3 Answers
SOURCE: Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
Posted on Dec 16, 2010
I have no spark on my briggs stratton450 series 148cc
I would suggest checking the saftey cable. They can stretch or get bent and will not allow the engine to start.
Jul 14, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Do i put 2 stroke or 4 stroke in a 148cc engine
does the engine take oil? if it does then it is a 4 stroke and does not require mixed gas. if it doesn't have its own oil then it is a 2 stroke and requires mixed
Sep 25, 2013 | Briggs & Stratton Briggs Stratton...
I have recently purchased a Morrison classic lawn mower it has B & S 430 series 148cc engine. It starts fine but it seems to run at about 85% with a slight cough/ splutter. Do you have any suggestions,...
it usually isnt the spark plug but it doesnt hurt to change it and the filter and the oil it is the carb they are not hard to rebuild most of the time you dont even need a carb kit although there only about ten bucks i suggest acid dipping it for 45 min i use chem dip about 25 dollars for a gallon then blowing out all the little holes with your air compressor shell run like new again
Aug 16, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
How to replace bottom bearing/seal on 20 hp kohler vertical shaft
You need to remove the engine and take out the bolts holding the upper and lower crankshaft housings together.
May 25, 2012 | Toro LX423 20HP Lawn Tractor 13AX90RS848
What engine other original will fit in mower?
Nearly any single or twin cylinder engine with the same configuration (ie. vertical shaft) will fit under the hood of a craftsman that used to run 20 HP.
Jul 26, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn mower will start, but won't move????
If you have had either of the rear wheels off, remove the cover from the center and observe the shaft with the engine running and transmission in gear. If the shaft is turning, you have lost the 1/4 inch key that locks the axle to the wheel to make it go
Sep 11, 2009 | Garden
Transmission reverse and 1 st gear, 20 hp
transmission and shifting problems are tricky. from the limited information given, i'll go on assumptions - if this is a hydrostatic transmission, your brake is stuck, it will need to be adjusted - if it is a six speed, several factors come into play. if it will shift okay with the engine OFF, but not with it running, you have a belt problem. has the belt been replaced recently? is it the correct belt? is the belt routed correctly? if none of the above, check the belt guides to make sure that a stick or something hasn't poked up there and bent them. their purpose is to make the belt "blossom" away from the engine pulley so there is no tension on the belt at the transmission. if it won't shift with engine off, the shift shaft in the trans is probably rusted and sticking.
Jul 01, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
