Question about Homelite Pressure Washer Pump 308653006
Can't remove pump from pressure washer
I removed mounting bolts but pump want slide off shaft
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Corrosion on shaft, keep tapping with hammer and levering off, spray shaft if possible and allow soak time, please be gentle, keep tapping. stay away from bolt holes as they are the weakest point, usually time to replace pump head,
Posted on May 15, 2014
2 Suggested Answers
jerry_kramer
  • 3904 Answers
SOURCE: Can't remove pressure washer pump from engine
Look closely. There should be a set pin or set screw on the shaft holding it in place. If not you will have to take apart the pump or the motor to get it off.
Posted on Apr 14, 2014
Tip
How do I get the pump off my pressure washer?
Removing the pump from a pressure washer can be easy, or it can be extremely hard. The first thing is knowing what you are going to remove and what you are not. Whether on an electric motor or a gas engine( the power source), a pressure washer pump consists of three parts; The manifold( the brass or aluminum part the water comes out of), the transmission( the oil side of the pump) and the flange( where it bolts to the motor or engine).
When removing the pump to replace it, you need to remove it at the flange. Normally after you take the three or four bolts mounting the flange to the power source, the pump will slide right off. Sometimes however, years of sitting out in the weather makes the pump stick on. There also might be a set screw holding the hollow shaft on to the shaft from the power source.
Make sure any set screws are loosened and try to pry the pump off by sticking a screwdriver between the power source and the pump and gently prying. If that doesn’t work try sticking the bolts back in the flange but very loose and starting the power source. The vibration from the motor or engine will break the pump loose most of the time. After that, if the pump is still firmly attached, you may need to either knock it off with a hammer (this will most likely damage the pump beyond repair) or use a torch and cut it off (this will damage the pump beyond repair and there is a chance you will damage the oil seal on the power source). If worse comes to worse you can take it to a qualified service center and have them remove the pump for you.
on Dec 22, 2009 | Garden
Apr 13, 2014 | Homelite Pressure Washer Pump 308653006
How to remove pump from a powerboss 020309 power washer
Remove the 4 mounting bolts and it will slide of the shaft if it's not rusted. If it's a little rusty it will take time and some good rust buster applied between the pump and engine onto the engine output shaft. Hope this helps, it's not always the easiest thing to do.
Sep 29, 2013 | Powerboss 020309 3000 psi 2.5...
How do I remove the pump" ANNOVI MODEL XTV from the engine on an EX-CELL pressure washer model # WGC 203 1? I want to work on the engine and don't want to damage the pump.
they are almost always on keyed shafts with maybe 4 bolts on a flange. remove the bolts and see if the pump slides off.... we have had many seized together and requiring extreme measure to part them (big hammer)
Sep 09, 2013 | Garden
How to change powerstering pump chevy uplander
I just finished replacing mine.
It is much easier if you do these steps:
1. Remove the serpentine belt.
2. Remove the nuts holding the main fuse box over the battery.
3. Remove the reinforcing bar over the battery.
4. Remove the battery.
5. Remove the windsheild washer tank.
6. Now you have access to remove the pump pulley. Without removing the stuff, it may be possible, but it will be extremely difficult.
7. Remove the pump pulley.
8. Loosen the high pressure hose fitting.
9. Remove the return line clamp.
10. Remove the power steering pump mounting bolts.
11. Remove the high pressure hose fitting.
12. Remove the power steering pump while sliding off the low pressure hose.
13. Remove the clips holding the reservoir on the pump.
14. Remove the reservoir.
15. Install new o-ring on the reservoir.
16. Install reservoir on new pump.
17. Install clips to hold reservoir on pump.
18. Install new o-ring on high pressure fitting.
19. Place new pump in position while sliding on low pressure hose.
20. Loosely attache high pressure fitting.
21. Tighten pump to mounts.
22. Tighten high pressure fitting.
23. Install clamp on low pressure hose.
24. Install power steering pulley.
25. Install washer reservoir.
26. Install battery.
27. Install reinforcing cross member.
28. Install fuse panel.
29. Install serpentine belt.
30. Bleed the power steering system.
Dec 13, 2012 | 2008 Chevrolet Uplander
Replace power steering pump on 06 chevy uplander
Jul 08, 2012 | 2006 Chevrolet Uplander
How remve john deere preesure water pum from motor
Hopefully anti-seize compound was used on the shaft of the engine when the pump was installed at the factory(most pumps will slip on either 3/4 or 1 inch shaft with key way). After you remove the four mounting bolts from the engine, the pump will slide off the shaft (most all do not lock the hollow pump mount to the shaft with set screw). Most likely you will need to work it off. Apply wd40 or Liquid wrench and allow some time for it to do its magic. If the pump is really stuck or rusted on the shaft, use metal wedges on both opposite sides between the pump and engine. Use caution when forcing the pump off because side plate of engine is not that strong. Good luck
Oct 27, 2011 | Garden
Ak38001 admiral washer need to replace drive belt
To change the drive belt you must unplug the washer and lay it forward on its front. Put some cardboard down so not to scratch the paint. Remove the two screws holding the rear panel and remove panel. Undo two bolts holding the pump on. There are three bolts holding the transmission into the washer. Locate the one bolt which has a spacer between the transmission and the post under the transmission. Remove the silver spring at the corner of the transmission. Remove the belt from the large silver pulley.
You will notice the part with the two coils called the wig wag. Under the left coil is a flat shaft. Rotate the large pulley to advance the flat shaft till its as far forward as possible. Insert a large screwdriver into the slot of the flat shaft until it comes out of the vertical shaft that it is inserted into by rotating the pulley with the screwdriver inserted into the slot in the shaft. Drop the vertical shaft till it almost comes out of the slot of the transmission it is inserted into. Tap the gray yoke off the top of the vertical shaft to allow enough room to slide the belt out. Slide the belt from where you removed the transmission bolt and spacer. You should now be able to remove the belt.
Slide the new belt through the space where the bolt and spacer was removed.
Slide the belt through where the vertical shaft was lowered.
Position the belt around all pulleys except the pump pulley.
Reinstall the transmission spacer and bolt.
Reinstall the flat shaft through the vertical round shaft by lining the flat shaft with the slot in the vertical shaft and rotating the large silver pulley until the flat shaft goes all the way through the vertical shaft.
Tap the yoke back into the top of the vertical shaft with the white plastic clip.
Reinstall the spring.
Line the pump pulley behind the belt and make sure the pump activator is positioned into the groove of the flat shaft controlled by the wig wag.
insert the two pump bolts.
You should be ready to go.
Jan 03, 2010 | Admiral Washing Machines
Broken belt . The belt broke on my ALW480DA Amana Washer. I can seem to be able to replace it becuase thre are four posts in the way holding the water pump housing. How can I change the belt.
you need to remove 3 or 4 bolts out of pump mount and slide pump down on shaft string belt and push pump back up and reinstall bolts in pump
Sep 26, 2009 | Amana ALW480DA Top Load Washer
Homelite Pressure Washer Pump 308653006 Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
