Question about KitchenAid KUDS30FXSS Builtin Dishwasher
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
I just moved into a new house where the KUDS30FXSS is installed. I tried to use it for the first time today, and it isn't working. The dishwasher turns on and sounds like the cycle is starting, but then there are a few clicks and the drain/cancel button lights up. Any idea what's wrong? This is a brand new dishwasher.
  • KitchenAid Master
  • 3,247 Answers
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
Posted on Apr 14, 2014
  • 3 Answers
SOURCE: My normal cycle and cancel button lights are
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Posted on Apr 27, 2009
SOURCE: Kitchenaid double-drawer dishwasher will not start
i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Posted on Nov 15, 2008
erpaalai
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
  • 784 Answers
SOURCE: dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Posted on Sep 13, 2009
SOURCE: My KitchenAid dishwasher (KUDS25SH) start and stop
MY KUDI25 CHWH1 has the exact same problem...I'd love to hear about a fix!
Posted on Mar 01, 2010
Dishwasher took 3 hours to complete cycle
If you have set the unit to heated water or your hot water is not hot will delay the wash cycle. The heater in the dishwasher is very slow!
The following is from the user manual.
15
TROUBLESHOOTING
First try the solutions suggested here and possibly avoid
the cost of a service call...
Dishwasher is not operating properly
Dishwasher does not run or stops during a cycle
Is the door closed tightly and latched?
Is the right cycle selected? Refer to the "Cycle Selection
Charts."
Is there power to the dishwasher? Has a household fuse
blown or circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shut-off valve (if installed) turned on?
Dishwasher will not fill
Is the overfill protection float able to move up and down
freely? Press down to release.
Dishwasher seems to run too long
Is the water supplied to the dishwasher hot enough? The
dishwasher runs longer while heating water. Refer to the
"Dishwasher Efficiency Tips" section.
A delay automatically occurs in some wash and rinse cycles
until the water reaches the proper temperatur
Hope this helps?
http://www.repairclinic.com/UserManual/f75a81f2957b4b86b396c8c3629d9078/8531130/Use-Care-Guides-Owners-Manual/Use-and-Care-Guide-8531130
Oct 16, 2016 | KitchenAid Dishwashers
Shuts off mid cycle
it is likely the heater or thermostat are faulty. Try to run in short cycle like rinse which works on cold water.
Apr 11, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
Kitchenaid DW KUDS30FXSS Cycle starts then I hear a solenoid actuate 4 times then unit goes into cancel drain cycle
Here's a link for the repair manual for your dishwasher:
http://www.appliancerepair.net/kitchenaid-dishwasher-repair.html
Concentration should be on Chapter 2 subsection 2-3 "No Fill"
Then go to Chapter 6; subsections 6-2, 6-3, 6-3a, 6-3b, 6-3c, and 6-3h for testing procedures on relays, actuator valves, etc.
Nov 30, 2013 | KitchenAid KUDS30FXSS Builtin Dishwasher
FOUL DOG SMELL
take all the food out wash it down and if that dose not work freebeez
Oct 27, 2013 | KitchenAid Kitchen Aid - KUDS30FXSS...
Kuds30fxss will not wash top rack
first ensure your machine is not set to half load, as this may only run the bottom shelf and not the top. also check the wather sprinkler rotor is not blocked. remove it and check the holes are free from debris.
i hope this was useful
Feb 15, 2013 | KitchenAid KUDS30FXSS Builtin Dishwasher
KITCHENAID DW KUDS30FXSS - 18 months old, will not complete cycles. Runs for 15 mins and stops & lights go out. Cleaning tablet often left in dispensor.
See my problem and solution. Sounds like you, too, are having a problem with the main control board (computer chip that controls the dishwasher), which is apparently a common problem with this model dishwasher. The part can be found here, for $211 (tax + shipping), and they have a 30-day return policy in the event that it does not fix the problem. It's an easy DIY fix. Hopefully this helps!
Aug 15, 2012 | KitchenAid KUDS30FXSS Builtin Dishwasher
Dishwasher starts but won't run through entire cycle.
Mar 17, 2012 | KitchenAid KUDS30FXSS Builtin Dishwasher
My Kitchenaid dishwasher is not turning on. I hired a repair man who charged me $108 to replace the fuse. The dishwasher worked for a few minutes, but then failed before the cycle was over. He then said...
something is blowing the fuse==a direct short somewhere. I would never use that repair guy again, $288 later, dishwasher should work. just trying parts is not a repairman, its a parts seller. if you cannot find the short, not worth replacing parts. and obviously 288 almost buys a new dishwasher. good luck and call his boss and complain about the repair and ask for your money back
May 05, 2017 | KitchenAid 24 in. KUDS01DLSS Built-in...
My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Apr 06, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid KUDS30FXSS Builtin Dishwasher Logo
384 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
