Question about Dryers
Kenmore model 110
My Kenmore washer gives the code 5d. Not sure what that means
    Problem Solver:
  • 8 Answers
Per Sears Repair Site code 5d is actually SD. Indicating suds detection. It displays when a drag is detected by basket of a suds lock condition. This is generally caused by using too much laundry detergent or the wrong type.
Posted on Apr 13, 2014
  • 7 Answers
SOURCE: Kenmore Elite Calypso Washer
take the pannel off the bottom and unscrew the pump cleanout
Posted on Feb 09, 2008
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Elite dryer Model:110.C60952990 almost no heat.
Before assuming you may have a component failure, do a little routine inspection of the dryer and exhaust vent ducting.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be because the exhaust ventilation ducting is clogged. If you can't remember the last time the exhaust vent was cleaned, or if it has never been done, this can contribute to dryer performance problems. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat, causing poor drying results and eventual failure. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced.
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted with the moisture from your clothing. If the exhaust vent is kinked or has excessive bends that create choke points, lint will accumulate in these points. Once the lint starts to accumulate, the moisture from your clothes starts to collect in it, and more lint get trapped. This eventually creates a clog. The Rule of Thumb: The SHORTER and STRAIGHTER the exhaust ventilation ducting, the BETTER.
A simple test to determine if you have a clog somewhere is to remove the dryer hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the back of the dryer should be forceful and warm (about 140 degrees). If the air flow is normal and the clothes dry as they should, then you need to inspect the ducting thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs.
If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect.
If your exhaust vent runs to an attic, this is a poor design that gravity will always win because of the resistance the blower fan meets trying to push the exhaust up the wall. The lint will eventually collect in the ducting going up the wall and have to cleaned out from time to time.
Also, make sure you don't crush the dryer hose behind the dryer when you push it up against the wall. You should always leave plenty of space behind a dryer to prevent this from happening.
Rodents and birds are anotehr cause of dryer problems. If they have access to the outside exhaust vents, birds will build nests in them and mice love a warm place with plenty of bedding material (lint makes a nice nest). Make sure the exhaust vent is at least a foot from the ground and use a louver type cover to keep pests outside. Do not use a screen. It can resist air flow and clog.
In addition, you should be using semi-rigid metal type ducting that resists kinking, crushing and rodent infestation.
If the air flow is weak, then you need to inspect the dryer INTERIOR to see if the air blower is working properly and is not clogged. It is important to keep a dryer checked routinely. Failue to do so can lead to component failures and is a potential fire hazard.
If you have questions, please let me know. I hope this helps you.
Posted on Sep 18, 2009
  • 4 Answers
SOURCE: my kenmore frontload dryer won't turn on; its
check circuit breakers/fuses located in house supply panel.
Posted on Feb 23, 2009
erpaalai
  • 999 Answers
SOURCE: I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Posted on Jan 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: just inherited a kenmore elite oasis dryer model 110 77092600
searspartsdirect.com - and enter your model #.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 27, 2010
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
My washer is displaying a 5d code on panel, what does this mean?
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jul 01, 2011 | Kenmore Front Load Washer
My kenmore washer is stopping constantly and has error codes like 5d, rL, F21 and some other codes. We checked everything the manual says to and it all seems fine. What is the problem?
That 5d is a clue. Too much detergent, the wrong detergent, or detergent in wrong dispenser can cause the 5d which is suds overdose. The F-21 is from banging on the touchpad in frustration!
Keypad error! Take the base panel off and find the tech sheet behind it. The tech sheet will give error codes and what to try. I have an HE washer service manual and some repair photos HERE
Jan 12, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Jan 11, 2010 | Kenmore 46462 Front Load Washer
Kenmore HE2t washer - error code 5d
5d is a definitely a the code for a plugged discharge. We removed the lower access panel and discovered a virtual treasure: $12.50 in quarters, nickels, dimes and pennies, a pen, a pencil, collar stays, 10 bobby-pins, 3 barrettes, a elastic headband, a draw string, a box cutter, 3 washers, 3 broken zipper parts, a elastic waist band. Amazing it took all to trigger a 5d error code. Hope this helps!
Dec 05, 2009 | Kenmore HE2 Plus Front Load Washer
What does code F21 mean on a Kenmore HE2 plus washer 11047532602?
it stands for longer than normal drain interval,press "pause/cancel" twice to clear, if it returns then look for obstructions in the water drain from the basket all the way to the drain in the house,or possibly it could be a bad washer drain pump
Nov 19, 2009 | Kenmore HE2 Plus Front Load Washer
Dryers Logo
50 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
