Question about Stanley Air Tools & Compressors
Bostitch stapler bought last year. not firing when the tip is on the work surface. Compressor is fine. Model SX1838
5 Suggested Answers
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
woobie dog
  • 1273 Answers
SOURCE: I just bought the Bostitch
Check the position of the switches and selectors. It sounds like you are in between settings. Also, put in a few drops of oil, and try your gun out on scrap wood, so oil doesn't come out on your good work.
--W/D--
Posted on Jan 21, 2011
  • 1388 Answers
SOURCE: Bostitch RN46 will not fire nail, only releases
Gun will not fire if air is leaking past orings in head /headvalve or safety /trigger is not pushing trigger pin all the way into trigger valve. Test: Remove trigger to expose trigger valve pin. Remove nails. Place nose of gun against thick rubber mat or coiled rubber hose to absorb blow of driver. Very quickly and deliberately press trigger pin all the way in. If gun fires, safety foo or trigger is not pushing trigger pin all the way in. Make adjustments or replace worn parts. If gun still does not fire, remove head and pull out headvalve. Apply lots of silicone paste lube on the orings and the surface of the head where orings make contact. Reinstall head and test as above. If the gun fires then orings were leaking. Replace orings and sand any scratches on body of cap with very fine sand paper. Parts are at www.toolpartsdirect.com Good luck
Posted on Mar 17, 2011
  • 885 Answers
SOURCE: Bostitch piston/driver replacement.
The driver guide just sits in the bottom of the head, the bumper sits on top of it and holds it in place.
Posted on Feb 29, 2012
Bostitch electric stapler wont open
Hello, Go to this website for support number and downloading of the operators manual for the model of stapler. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
May 01, 2014 | Stanley Bostitch B8 Electric Stapler
How do I put the Bostitch B660 stapler back together?
MAYBE THIS IS USEFUL http://www.ereplacementparts.com/bostitch-21680b-industrial-fine-wire-stapler-parts-c-29443_29444_29449.html
Apr 02, 2012 | Air Tools & Compressors
Feb 23, 2012 | Hitachi Air Tools & Compressors
I have a bostitch floor staplet 111 and when I hook up the air to it air leaks out of the top and runs all of the air out of compressor please help
Below the rubber bumper is the poppet actuator. The actuator has 3 screws that attached it to the actual poppet below. If the screws do not seat well and/ or if the gasket between these two parts is bad, air will leak out the top. Remove the poppet actuator to check oring on the actuator and the surface of the body of the gun where the oring makes contact. Look for damage to actuator or side wall and repair as needed (sand sidewall where oring makes contact with very fine sandpaper if scratched or dented). If oring does not fit snuggly against sidewall, use teflon tape below oring. Parts are available at www.bostitch.com.
Feb 15, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
My bostitch compressor staple gun is not working. The compressor itself works fine, the other two guns work, but the staple gun-when you depress the safety and pull the trigger, the air comes out from...
If its the stapler I believe it is (SX1838) it has a broken driver. These staplers have a factory flaw in them, the drivers are faulty. Bostitch has since repaired the problem from the factory but their are still nailers out there that have this problem. Sounds like you have one of them, its an easy 5 min fix but you need to go to a Bostitch cervice center in your area and get a fresh driver installed. Your stapler has a 7 years warranty so it won't cost you anything. As a Bostitch service center I have done hundreds of those staplers, once the driver is changed ou shouldn't have this problem anymore.
Jan 04, 2011 | Stanley Air Tools & Compressors
I have a model B310HDS heavy duty stapler and the spring mechanism broke on the end. Where can I find the replacement part? Thanks
what you are looking for what they call a pusher assembly.
Bostitch company uses Amex(SP?) for their replacement parts.
The phone number is 800-343-9329
Jul 21, 2010 | Stanley Bostitch 00540: 00540 AntiJam ?...
Air Tools & Compressors Logo
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
