Question about Whirlpool LGR7646E Dryer
My dryer will turn on but the igniter will come on but goes right off
    Sergeant:
    Champion:
  • 257 Answers
Call whirlpool, or email them. lol.
Posted on Apr 14, 2014
White Knight gas tumble dryer BG 457 starts and ignites with the orange light coming on, works for about a minute producing heat then the orange light goes off. The dryer continue to turn but the orange...
I feel you need a new igniter or thermocoupler. Just remember those igniters are activated many times to keep constant right heat for the machine to do its job.
Jan 25, 2018 | Dryers
My dryer turns on, will click then the fire ignites, but goes out after a few seconds, so it is not staying on, and it takes two and three cycles for my clothes to dry, is it the igniter?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer won't light. Igniter glows, then turns off,
heatman101
Jun 25, 2011 | Frigidaire Dryers
I replaced the timer and it still dosen't work and clothes don't get dry
you have to check the igniter fisrt, if your dryer is white you have a plug at the lower left corner, remove it,turn the dryer on and look for the igniter to glow. if you see no glow after 1 minute replace the igniter. if it glow and goes off and no gas is ignited then replace the coils.
Feb 13, 2011 | Roper RGX4634KQ Gas Dryer
Maytag neptune gas dryer dryer will run but the igniter will only ignite part of the time, thought we had a bad igniter put in a new one, it lit up right away dryed one load completely dry, put in the next...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Maytag Dryers
Igniter lights, gets hot then it turns off
Check for a clogged vent, or a stretched out belt.
Jun 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
My dryer is gas. The problem is that when I turn on the drier the flame ignites and after a while goes out and does not re-ignite.
This is most likely caused by faulty gas valve coils. These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. Faulty gas valve coils are a common cause of "cycling". It is recommended that if any coils are suspected of being faulty that both (all) be replaced at the same time. Hope this helped and best wishes.
Sep 05, 2009 | Dryers
Dryer worked well until recently. Igniter glows
I would take a look at the gas coil solenoids. The gas coils are right above the gas valves. They are black electrical coils. When energized, the coils open the gas valves. If one or more of the coils is defective (bad solenoids), then the gas valves won't open and the gas cannot ignite. Because it's difficult to test the coils, it is best to replace both (all) of them at the same time. Sure hope this helped and best wishes.
Jul 28, 2009 | Dryers
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
