Question about Kid Trax 12V Charger Police Car
What is buzzing sound coming from relay? - Kid Trax 12V Charger Police Car
Truck won't start i have a buzzing sound coming from the fuse box any diy suggestions
Sounds like the fuel pump relay is buzzing. Try swapping it for another relay...something like power seat or window.
Jul 27, 2016 | 2003 Ford Expedition
Buzzing sound coming from under the back end
Under the left side of your back seat is a fuse / relay box . When you first turn the key on the fuel pump relay turns on for a few seconds to prime the fuel system . That relay is in that fuse / relay box ,that is what your hearing . Does the vehicle start an run good , no problems other then the buzzing sound .The vehicle battery is also under the rear seat on the right side . How To Locate and disconnect Battery Buick Lesabre Pontiac Bonneville 00...
Feb 19, 2016 | 2002 Buick LeSabre Custom
My mazda buzzes 2 times when I turn the headlights off and the instrumentation lights flash at the same time
Mazda 626 Electrical Issues - Car Forums at Edmunds.com
forums.edmunds.com > Mazda > Mazda 626
May 22, 2007 - 31 posts - ‎24 authors
clicking or buzzing sound coming from the "headlight relay" which is in ... off when you turn on the headlights then it clicks instead of buzzing in that fuse compartment and the headlight flickers about 5-10 times a second in time with the ..... I have a 1992 626 mazda, the battery died and replaced it two days ...
Thread: headlight issue and buzzing sound - Toronto Mazda 3
www.torontomazda3.ca > Forum > Technical Section > Electrical
Mar 3, 2009 - 25 posts - ‎10 authors
1. so in the fall my right headlight burned out, but then after nudging ... 2. sometimes when i turn off the car i hear buzzing coming from .... i turn off the car, was never able to open the hood in time before the sound disappears ... Buzzing sound behind centre console
Sep 17, 2010
HID Problem: Bulb/Ballast Misfiring
Aug 28, 2010
Buzzing relay after HID install with RELAY harness ...
Mar 12, 2008
More results from www.torontomazda3.ca
Jan 07, 2016 | Mazda Cars & Trucks
Turn signals buzzing?
check your relay for flasher
Nov 07, 2013 | 1998 Audi A4
Refrigerator makes a buzzing sound for 10 seconds clicks and stops making the sound. This happens every minute or so
I believe that buzzing sound is coming from the start relay and the click is the overload clicking because the compressor is trying to start but cannot because the start relay is defective, You may have a run or start capacitor bad also, Thanks Sea Breeze
Model Number?
Nov 17, 2012 | Refrigerators
Ignition switch turned on all power is drained and a buzzing sound comes from the dash driver side truck won't start
This sounds like one of two things. The buzzing is sometimes a key in the ignition reminder in lieu of chimes, or the bad Relay is vibrating.
Sometimes when Relays go bad the contact points melt together. But what most people do not realize is that Relays operate in a domino sequence and have 2 or more sets of contacts in each Relay. One relay activates a second relay. With the points frozen in the first relay, the second relay in domino sequence is turned on with no job to do. The spacing between the contact points and its coil continue to buzz because it is not able bite into its matching contact.
First, you can get free Powerbox diagrams by registering your truck on Autozone.com. The wiring diagrams are also free. This will give you a clue to which relay goes where and does what.
Find the buzz. The vibration should be coming from the relay that is the problem, or connected to the problem. If you think about it, a stuck Relay can drain the power. The source of your original problem.
Have you recently used the trailer plug? What does not work on the truck? Horn? Door locks? Window motors? Seat motor? Rear window?
Was something plugged into a power outlet? Cell-phone, I-pad, etc.
Finally, disconnect and fully charge your new battery. Ford alarm systems are very, very sensitive to low power. Unplug the alternator to see if the noise is coming from bad Diodes grounding the alternator.
I hope my solution helps and would like to know the results of this mystery sound to share with others.
Sep 17, 2012 | 1997 Ford F150 Regular Cab
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
Windows won't operate. Buzzing sound comes from under dash when either switch is depressed. Need trouble shooting help?
There should be a window relay near your fuse box under your dash. See if there's another relay you can pull and swap to test. Chances are the relay went bad considering you're hearing a buzz from under the dash.
Nov 30, 2009 | 2003 Ford Ranger Regular Cab
Fridge not cooling, freezer not freezing, buzzing sound
with any luck this is you overload and relay
it is the plug on the actual compressor, this is very easy to replace, if you replace it and it does exactly the same thing its your internal relay and your compressor is done....
Oct 02, 2009 | Maytag MTF2155GRW Top Freezer Refrigerator
Kid Trax 12V Charger Police Car Logo
635 people viewed this question
Top Kid Trax Toys Experts
ray gallant
Are you a Kid Trax Toy Expert? Answer questions, earn points and help others
