Question about Ovens
Kleenmaid fec 500x
The fan gives no hot air, other oven functions all work
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Fan forced heat not working
If it is an electrically heated fan oven, then it sounds like the oven element is not working.
This is usually located at the rear rof the oven behind a removeable cover.
Hope this helps.
Posted on Dec 06, 2009
venexcsd
  • 1185 Answers
SOURCE: Smeg fan oven not working, all other functions ok
You need to place use a multimeter to check the element for continuity if that is ok then the next step is to check for 240v being
switched to the fan and element array.
With the unit switched off at the wall put the test leads onto the correct points ( Use the earth post for the Black lead) switch the meter to a range to cover the 240vac and then switch on the unit
If there are no readings then you need to go back up the wiring to check the input to the thermostat
Posted on Feb 24, 2010
  • 51 Answers
SOURCE: need a manual for my
http://www.tradebit.com/filesharing.php/search/0/kleenmaid/0/1
Posted on Sep 18, 2010
SOURCE: The top oven does not get hot. All other
Replace the top over relay board.
Posted on Jan 22, 2011
The fan in main oven only blow out cold air
The fan does not produce hot air. It just circulates it. The thermostat turns on the heating element and the fan moves the hot air around. Unless you have an odd working machine. Baked bread for years an it only moves air for even heat.
Jan 31, 2015 | Ovens
Bosch oven temp control
If the temp control works for all other settings, it is working for hot air grilling as it using the same stat....when hot air grilling function is used the grill comes on and when it reaches temp the element switches off and the fan switches on. Once this has happened the element and fan will alternate during the cooking period. The fan and element DO NOT operate at the same time.
Mar 23, 2013 | Bosch Ovens
Kleenmaid G10-FF6 Manual
Hi Andrew,
I tried looking for the manual but couldn't find it. Here's what I found:_____________________Urgent Information for Kleenmaid CustomersKLEENMAID LIQUIDATION NOTICEThe Kleenmaid Group was placed into liquidation in May 2009.
Kleenmaid Customer Solutions, the former Kleenmaid appliance service business was acquired by Aussie Whitegoods Rescue. For service, spare parts or sales on replacement product please phone or email our contact centre.
For further information relating to the liquidation of the Kleenmaid Group, please visit the Deloitte website www.deloitte.com.au or email kleenmaid@deloitte.com.au
For Service, Sales & Spare Parts you may call Aussie Whitegoods Rescue at Phone # 1300 652 100. Trading Hours 8.30am - 5.30pm Mon - Fri EST
They might be able to help you with the manual for your oven.
I hope this helps.
Dec 05, 2011 | Ovens
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Need a manual for my old fan forced Kleenmaid by brandt oven.......no other model markings on oven
Sep 15, 2010 | Ovens
In fan mode oven very slow to heat up [ fan is working] all other functions ok
If you can, test the oven fan element, if you can't, then feel \at the back of the oven compartment in front of the fan, you shoud feel hot air blowing, if not, then you need to replace the oven element.
Please rate my solution.
Thanks.
Nov 04, 2009 | AEG B5741-4 Electric Single Oven
Kleenmaid Scala wall oven and grill
manual available at www.kleenmaid.com/care
Jan 17, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
