Question about Sony BDP-S300 Blu-Ray Disc Player
No disk vcr works. after insert dvd the tv screen reads..no disk
2 Suggested Answers
  • 188 Answers
SOURCE: DVD Player cannot recognize any DVDs
Laserunit faulty.Did you cleaned the laser allready?
Posted on Jul 30, 2009
Model LGXBR446 VCR/DVD Recorder, Have to go input on the TV to get the unit to Play, Does not play Automatically when turned on an disk or VCR inserted, Also the color is not correct
I think I know what the "skin tones blue" problem is-you probabaly have the composite video(for the old video-on-one-cord format) connected to the blue of the component video input.(component video is the red/blue green RCA type connectors).
May 31, 2012 | LG XBR446 DVD Recorder/VCR
How can I get my DVD to get unstuck out of my VCR/DVD player?
I can't get any support from sansui. I think your DVD player is trying to read the disk. It can't and its stuck in DVD mode. This is just something I would try I don't know if it will work. Unplug the power source hold down the eject button and plug it back in. The objective is to try to get it to spit that disk out before it has a chance to try to read it.I hope this helps. If it does give me a vote and I'll know it worked.
Mar 04, 2010 | Sansui VRDVD4001 DVD Player/VCR
Wont play dvd's.
If this happens when you insert a DVD disc then most likely the laser assembly is failing in the DVD drive. In most cases it will probably still play CD's. The part number needed is LSVQ0087 and isn't cheap as seen on the following ebay posting. Please take a moment to rate my answer. Thanks.
http://cgi.ebay.com/Panasonic-LSVQ0087-BLOCK_W0QQitemZ390013781267QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5acea20513
May 10, 2009 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
DVD player will not work. Set up unit in January 2009 and worked just fine. Now each time a CD or DVD is inserted the machine says "bad disk". So no movie or music because machine will not read or...
you need to go to a walmart or radioshack store and buy a cd head cleaning disk. then just follow the instructioins and you will be back in business
Apr 01, 2009 | GoVideo Go Video DVD/VCR Combo
DVD is stuck in my JVC VCR/DVD Combo
Find the small hole on the front of the player. Get a small paper clip and straighten it out. Insert one end into the hole and the DVD should pop out.
Feb 20, 2009 | JVC HR-XVC19S DVD Player/VCR
When the DVD is inserted, an error appears
have you tried or have you been using a laser lens cleaning disc ?
if not then the glass lens will need to be manually cleaned with a q-tip and lens cleaning solution
Feb 19, 2009 | Philips Magnavox DVD/VCR Dual Player
LG RC797T Won't read disks
I had this problem last year. It had to be sent back to the company to replace the entire dvd unit; however, I found that it probably had been caused by electrical surges. Once I got it back after repair (replacement) I put the best possible surge protector I could buy on it and have not had a problem with that issue again. The idea of a surge problem came about because I blew 3 Onkyo stereos while still in warranty several years ago and they did the same thing- would not read discs, would say no disc, etc. & the protector ended the problem.
Dec 19, 2008 | LG RC199H DVD Recorder/VCR
Unable to play a DVD movie
Most probably the TV system is not compatible.
This VCR/DVD uses NTSC formate. Is the DVD in PAL formate. Also the Region code can be different. This DVD palys DVD-Disks with regional code 1 or All.
Dec 09, 2008 | GoVideo DVR4300 DVD Player/VCR
GoVideo DVD combo
Hi - I can record a dvd from the tv and can play it back but when I try to play a store purchased dvd it ejects the dvd and on the tv screen it says unknown disk, please, check disk again.
Aug 19, 2008 | GoVideo Go Video DVD/VCR Combo
Sony BDP-S300 Blu-Ray Disc Player Logo
21 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
