Question about Cuisinart Cwc-1600 16-bottle Wine Cellar Silver
Wine fridge will not get cold
Everything posers on fine and you can adjust the temp up and down and turn the light on and off but it will not get cold.
  • 41 Answers
Compressor gone or gas leak
Posted on Apr 14, 2014
Not cold my mini wine fridge is not putting out cold air anymore. The lights and everything seems to be work fine
i. Carefully check your door seals for gaps / leaks.
ii. Freon or other refrigerant may be low.
iii. Compressor could be faulty.
iv. Thermostat maybe incorrectly set or faulty.
v. Somebody is drinking your cold wine and replacing with warm stock. ;)
Nov 20, 2017 | Furniture
I have a CWC 1600 everything works fine on it but it does not get cold. Everything powers on fine and you can adjust the temp up and down but it just does not get cold.
Your Peltier is most likely shot! You can fix it for less than $10 in about 30 minutes.
Take the back of the fridge apart and remove the fan and aluminum heat-sync. Sandwiched in between the heatsync you'll see the Peltier pad with two wires coming off it. That's what you need to replace. The peltier has a make and model number on it. I would recommend ordering the same make and model. The specs should be 12v DC and less than 5amp and 60 watt draw. Your wine cooler's power supply can only output 5amp and 60watt max power. When you install the new Peltier you'll need to spread new thermal compound on both sides of the Peltier. I recommend Artic Silver Ceramique. You can buy this at your local Radio Shack or any computer store where they sell motherboards and CPUs.
Ceramique Thermal Compound
Apr 13, 2014 | Cuisinart CWC1600 Wine Cooler
Fridge will not turn down
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Liebherr KES3660 Stainless Steel...
Ge freezer works fine but the fridge wont cool.you
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
My model MFF2557KES refrigerator not getting cold and freezer operating fine.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
Sep 07, 2009 | Maytag MFF2557KES 25 cu. ft. French Door...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Coldspot EM5119829. The Freezer works
or..
Sep 03, 2009 | Refrigerators
Fridge not cold as should be
OR.
Aug 29, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Zanussi fridge compartment has stopped cooling but freezer is ok
OR.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Freezer works fine but refrigerator is not cold
OR
Aug 18, 2009 | KitchenAid Refrigerators
Cuisinart Cwc-1600 16-bottle Wine Cellar Silver Logo
224 people viewed this question
Top Cuisinart Refrigerators Experts
Brian Coughlan
Tom Chichester
Darrell
Are you a Cuisinart Refrigerator Expert? Answer questions, earn points and help others
