Question about Cuisinart CWC1600 Wine Cooler
I have a CWC 1600 everything works fine on it but it does not get cold. Everything powers on fine and you can adjust the temp up and down but it just does not get cold.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Your Peltier is most likely shot! You can fix it for less than $10 in about 30 minutes.
Take the back of the fridge apart and remove the fan and aluminum heat-sync. Sandwiched in between the heatsync you'll see the Peltier pad with two wires coming off it. That's what you need to replace. The peltier has a make and model number on it. I would recommend ordering the same make and model. The specs should be 12v DC and less than 5amp and 60 watt draw. Your wine cooler's power supply can only output 5amp and 60watt max power. When you install the new Peltier you'll need to spread new thermal compound on both sides of the Peltier. I recommend Artic Silver Ceramique. You can buy this at your local Radio Shack or any computer store where they sell motherboards and CPUs.
Ceramique Thermal Compound
Posted on Apr 14, 2014
Is there a replacement circuit board for the Cuisinart CWC-1600 unit?
The actual manufacturer of the circuit board out of China does not seek direct, but you may be able to order a replacement board through cuisinart support. More than likely your board is fine, but rather your power supply has failed. Check my post on how to replace the power supply for under $20
Jun 17, 2014 | Cuisinart CWC1600 Wine Cooler
TEMP GUAGE JUST QUIT WORKING. COOLANT LEVEL IS FINE, HOSES ARE FINE. EVERYTHING IS COOL TO THE TOUCH. TEMP GUAGE READS BELOW COLD, YET ELECTRIC COOLING FAN COME ON WHEN ENGINE IS SHUT DOWN.
your gage has just gone out and needs to be replace. the computer control the fan. so as long as the temp sensor is connected to the engine it will work fine but you will not know the temp of your vehicle.
Nov 30, 2010 | 2001 Chevrolet Malibu
Side by side refrigerator the refrigerator does not get cold but freeze works fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Jan 01, 2010 | GE GSS25JFM Side by Side Refrigerator
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 14, 2009 | Refrigerators
My model MFF2557KES refrigerator not getting cold and freezer operating fine.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
Sep 07, 2009 | Maytag MFF2557KES 25 cu. ft. French Door...
Kenmore Coldspot EM5119829. The Freezer works
or..
Sep 03, 2009 | Refrigerators
Fridge not cold as should be
OR.
Aug 29, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Zanussi fridge compartment has stopped cooling but freezer is ok
OR.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Freezer works fine but refrigerator is not cold
OR
Aug 18, 2009 | KitchenAid Refrigerators
Cuisinart CWC1600 Wine Cooler Logo
527 people viewed this question
Top Cuisinart Refrigerators Experts
Darrell
richie46
Are you a Cuisinart Refrigerator Expert? Answer questions, earn points and help others
