Question about GE PFDS450GLWW profile 7.5 cu ft front load gas dryer with steam
Dryer won't tumble and hums - GE PFDS450GLWW profile 7.5 cu ft front load gas dryer with steam
    Sergeant:
  • 239 Answers
Broken belt or belt jumped off of the tension wheel...
Posted on Apr 14, 2014
Dryer won't tumble.
check the belt............if ok then could be the motor ..........cheers
Apr 15, 2014 | Whirlpool WED9600T / WED9600TA / WED9600TW...
Lg tdc70045e dryer
Sounds like your motor has packed up
Jun 13, 2013 | Dryers
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
My Frigidaire Affinity dryer won't tumble; it just hums
Thats not even a question Stupit!!!! A good hummer is good for you ********!!!!
Aug 04, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool LER 6620 heats, but does not tumble.
if the dryer heats the motor should be good. if it hums its either runing or the hum is a stall noise . if belt is in tact then if motor were going so would the drum . so i think the motor isn't going just humming and the heat sw in the motor is stuck closed with lint and you need to replace the motor .. take the belt off and turn motor if it turns free . the blow it out good and reinstall belt and try again ..mm
Dec 03, 2009 | Dryers
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
Dryer hums but won't tumble. I can manually turn
most likely motor will need to be replaced if you do repair try to remove blower wheel first you will need a 1/2" rachet and a 7/8 for the motor to hold motor in place you may need to replace also they will lock together some times
Sep 26, 2009 | Kenmore Dryers
The dryer will not tumble
do you hear any humming noise? does the heat come on?....no noise. most likely is a thermal fuse....small white fuse usually with two blue wires. humming means broken belt, bad motor or something stuck in blower wheel.
Jun 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
Dryer not tumbling
Broken drive belt, or drive belt disengaged. Or stretched. Or lost tension spring. Humming is motor running, not driving drum.
Jan 21, 2008 | LG DLE5977 Electric Dryer
GE PFDS450GLWW profile 7.5 cu ft front load gas dryer with steam Logo
44 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
