Question about Garden
I have a riding mower 2013 Husqvarna LTH18538 and I ran over the garden hose how do I get it loose?
    Guru:
  • 145 Answers
Safety First! ENGINE OFF, WHEELS BLOCKED SO YOU DONT RUN YOUR SELF OVER, SPARK PLUGS DISCONNECTED, IGNITION KEY IN THE HOUSE AWAY FROM THE CURIOUS.
you will need to follow the manual, remove the cutting deck from the tractor turn upside down and remove it the best way you know how Chainsaws Lawn Mowers Tractors Blowers Trimmers Snow Throwers Husqvarna
Posted on Apr 14, 2014
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
Posted on Apr 06, 2009
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
mowerman1857
  • 389 Answers
SOURCE: How do you remove the electric clutch from a
Remove the primary belt and mowing deck to give yourself some room to work.
Locate the wires from the clutch and follow them toward the frame until you find the plug and unplug it.
Remove the bolt and washer from the center of the clutch going up into the engine crankshaft and slide it off the shaft. It is quite heavy so be careful when it comes free.
Posted on Sep 23, 2009
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
My husqvarna lgt2654 riding mower stopped during mowering the grass,black wire underneath the blades was ripped. Where does it go.
there is no wiring under the blades on any mower made .possibly the PTO wire came loose and got cut off .
Sep 24, 2016 | Husqvarna Garden
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
What's the belt demention on a 2013 rz4623 husqvarna. The mower is discontinued
still plenty of parts available,the dimensions arent included,but you can find cheaper belts,just dont use an automotive belt,they wont last through 1 mowing,get the ones with kevlar,they r more expensive but,will last for a long time, Husqvarna Drive Belt Part 539117245
https://www.bing.com/search?q=husqvarna+539117245&PC=U316&FORM=CHROMN
your complete parts manual,,, Husqvarna RZ4623 Ride On Mower Parts
Jul 17, 2015 | Garden
Husqvarna instructions
The instruction are in your owners manual. In case you thrown them away here the 2013 owner manual look on page 23.
http://cdn.husqvarna.com/ddoc/HUSO/HUSO2013_NAenNAes/HUSO2013_NAenNAes_LTH18538_585996126.pdf
Aug 16, 2014 | Husqvarna LTH18538 38" 18.5HP Lawn Tractor...
Mower shuts off after running about 5 minutes. i blew thru gas line towards tank and seemed like there was resistance tnen it opened up. ran another 5 minutes and same thing happened . model is husqvarna...
Check the fuel tank cap. It needs to let air into the tank and has a small hole to enable this. Try running the engine with the cap loosely in place to verify this is the cause. If you can't clean it get a new one.
Jul 01, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna riding lawn mower pto is not engaging?
when you dropped the deck did you knock off the pto electrical plug?
Mar 31, 2012 | Husqvarna Garden
Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
