Question about T-Mobile Prepaid Alcatel One Touch Evolve 3G
Actel phone says error code 67 - T-Mobile Prepaid Alcatel One Touch Evolve 3G
How do i fix my sprint zte phone that has an error code of 'mip 67 ??
"Try checking your SIM card number, make sure it matches with what Sprint has,i had the same issue no 4g and the error you were mentioning. My SIM card number was different then what Sprint had, they just updated the number i gave them and works awesome."
May 06, 2017 | Sprint Cell Phones
How to fix buffering problem on my Actel OneTouch shockwave
App 3c toolbox will let you change buffer size which will probably fix the problem
Jan 28, 2015 | Alcatel Cell Phones
Error code 67 won't connect to internet
You have to reset your phone by pressing specific numbers on your dial pad you`ll receive those numbers from your mobile provider so you must call them and also ask them for your access code doing this will delete all the information on your phone but it is the only way to get rid of error code 67.
Jan 15, 2014 | Net10 LG Optimus Logic Cell Phone
Error 76 and 67
what year, my gosh.......
Misfire Cyl. 6 Or Random Misfire
and forget 67, Cat weak, misfire cause CAT overload.
http://www.troublecodes.net/honda/
Sep 29, 2013 | Honda Cars & Trucks
Straight talk huawei ascend network error code 67
I HAD ROOT BEER FLOAT SPILL I CLEANED IT AND EVERYTHING WORKS BUT NO SERVICE, SAYS ERROR 67 WILL NOT LET ME TEXT AT ALL AND HAVE NOT RECEIVED MY TEXTS PLEASE PLEASE HELP
Mar 25, 2013 | Cell Phones
Error 67 with HotSpot
Error 67 typically has to do with a problem with data. Updated PRL, Profile and the different resets will typically fix this issue. Your best option would be to wait and see if they call back if not give them a call and ask for a credit on your account.
Mar 11, 2013 | Cell Phones
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Jul 14, 2012 | LG LD651EBL Dehumidifier
Fix error code 67
Error Message
"Data Call Failure
Error Code : 67
Error Code 67 Registration Failure. Your PCS Vision username and/or password may be incorrect. Please try again."
This error message is an example of the error message you might have received. You may find that your computer is running slower than you first got it. After frequent use, you may also have system crashes or even blue screen of death.
We strongly suggest that you run a quick scan for error code 67 for your PC to check and fix the errors.
Buy Now (Only $34.95)
30-Day Money-Back Guaranteed
What Is Error Code 67? One thing you should know is that when you access the Internet, your system will have some access to the recourses of a remote computer. If the name of the particular network cannot be found, error code 67 will show up to your computer screen. And you will not be able to use the resources provide in the network.
Fix Error Code 67 Error Now! How to Fix Error Code 67? Sometimes, Windows error codes also indicate a faulty hard ware in your computer. It could be a hard ware that has not been installed properly. Or it could also be insufficient free space in your hard drive. When you receive error messages like that, you should go and check the condition of your hard drive immediately in case of further damages.
Now that you know what the causes of error code 67 are, you have to learn to fix the relating problems. To do this, you can take a look at the tips below:
  • Remove files you do not need from your hard drive. You might have stored files in your computer like movies, music or images that you have accessed for a long time. If you do not need these files, you should better delete them from yourcomputer. This will ensures the sufficient free space in your hard drive.
  • Uninstall unnecessary software and disable startup programs. If you have some software that you no longer need, uninstall them from your computer. Besides, too much startup programs will hinder the process of starting up of your system. You could check and disable the programs you do not need in startup.
  • Scan your system in a regular basis. If your computer keeps on giving you error messages and your system performs slower and slower, you should pay attention to the safety of your computer. Chances are that your computer has been infected by virus or Trojan that hinder the efficiency.
  • Clean your registry. If the registry of your computer is corrupt, you would also receive irritating error messages. So you should scan your registry, identify and fix all the errors in your registry.
Jan 29, 2012 | Refrigerators
T-Mobile Prepaid Alcatel One Touch Evolve 3G Logo
24 people viewed this question
Top T-Mobile Prepaid Cell Phones Experts
Willie Mondo
Willie Mondo
sandrasteven
Mister Danger
Are you a T-Mobile Prepaid Cell Phone Expert? Answer questions, earn points and help others
