Frigidaire top load wont fill with water, and all other functions are working
    Sergeant:
  • 239 Answers
Sounds like the solenoid fill valves where the hoses connect to the machine have gone bad.
Usually, it's just a matter of unplugging the machine, turning the water valves off a the supply connections, disconnecting the hoses, opening the entire top of the machine or removing the back panel, removing the plastic hot/cold water mixing valve assembly, getting a replacement assembly, and connecting the wires to the same connections after mounting the new valve assembly.
Close it up, reconnect the hoses turn the water back on, plug it in, and try it.
Posted on Apr 14, 2014
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
Illeagle
  • 525 Answers
SOURCE: washer does not fill
Firstly, check to see that your water temperature is selected properly. Next, check to confirm water supply to the washer is adequate, both HOT and COLD. If confirmed, try replacing the fill valve.
Posted on May 27, 2008
SOURCE: my washer won't stop filling
I have a Maytag that had that problem. Mine has a plastic tube inside of the machine that connects to a sensor. As the water level rises, some of it goes into this tube creating air pressure on a sensor that signals the machine that the water is at the selected level. The bottom of the tube had come loose and just needed to be put back onto the fitting. I accessed this tube by lifting the top of the machine, and it is in the back. Very easy to get at. I hope this works for you.
Posted on Sep 22, 2008
marka19
  • 1430 Answers
SOURCE: Frigidaire FEX831CS Top Load Stacked Washer won't
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topwaterinletvideo.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on Jun 03, 2010
Top load washer will not fill with water. Doesn't matter what setting. Other functions appear to be working but no water.
Check to make sure you have power to the pump...if not, trace it back to the relay that kicks the pump on & see if the relay is energized.
Dec 18, 2013 | Frigidaire FGX831C Top Load Stacked Washer...
Frigidaire gallery top load washer
After 13 appliance years, your washer is a candidate for replacement.
Aug 08, 2017 | Frigidaire CWS3600AS Top Load Washer
We have a frigidaire washer dryer combo. after a bad storm (our electric kept flickering off and on) our washer no longer works. we noticed that it would only fill up with water while dryer was on. now it...
Possible damage on the program control panel as it is most likely to be damaged due to a power outage. remove panel and check to confirm if the board is burnt or damaged
Jul 03, 2012 | Frigidaire FLEB8200DS Top Load Stacked...
My Frigidaire GLWS1339CS1 fills but stops about 2 inches from the top? It has done this since I bought it and otherwise works fine. A tech came out and told me to fix it would cost more than buying a new...
The washer will not fill all the wayto the top.yourmachine is functioning properly.when you have an empty tub and put it on super load and fill it up there should be 12 to 14 inches of water in the tub. that is the normal operating settings for your washer.
Oct 03, 2011 | Frigidaire GLWS1349A Top Load Washer
Water level only works on medium setting. other settings keeps running water and wont fill tub.I have to manually change each cycle...example.. from wash to rinseto spin.
If it used to work then the most likely problem is a faulty water level sensor or blockage in the tube going to the sensor.It is not supposed to fill to the top, are you sure the water level is wrong?
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
Wont fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
sgsg
Jan 03, 2010 | Frigidaire GLWS1749A Top Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Fills with water and that's it
ck the water pump, only if it agitates but doesnt drain. If it completely stops after filling, ck lid switch(should here clicking noise from sw.)
Oct 21, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
