Question about Gateway At&t 2701hgv-b 2wire Hi Speed Internet Wireless Modem Router Uverse Att
Dynex tv won't give me the option to connect to a wireless network. It defaults to wired
Ddynex tv won't recognize att uverse wireless router
    Scholar:
  • 99 Answers
This would normally indicate either a compatibility problem, the wireless network is not broadcasting, or you do not have enough signal to see the network. First thing I would try is most devices that can connect to WiFi have the option of connecting to a network that is not listed. I would try that. If that still does not work I would then try disabling all wireless security on the router just to see if that will work(I do not recommend leaving the security disabled any longer than it takes to test this). If none of that works then the next thing would be to check the signal. If you have a laptop, tablet, or cell phone that is connected to your wireless network then bring it over to the tv. If you loose signal, or have low signal then you will need to find a way to get more signal. Even if you do not see low signal on other devices the tv can still have too low signal partly because the antennas are usually in the back where the signal would be blocked by the tv as well as any other equipment you may have around the tv. Try to make sure that there are no metal objects between the tv and the router, and if possible try to get the router as close to directly behind the tv as possible. The more walls the wireless signal has to go through the weaker the signal will be, and metal can reflect the signal, completely blocking it, as well as causing noise on anything near the metal.
Posted on Jul 12, 2014
My laptop does not recognize my printer in a wireless connection. After I changed my internet connection to Att-Uverse my laptop does not recognize the printer after I installed the software of my brother...
Reinstall the Printer on the laptop, using the WiFi connection choice when it comes up in the install wizard. The Driver will "Scan" the network and find the printer.
Jan 20, 2018 | Brother MFC 7840W Printer
Ethernet (wired) connection to computer works but "wireless" light does not come on and my laptop cannot locate a wireless access point or network device. It has worked in the past but after...
You will need to get a hold of att. They will need to have you unplug the 2wire and then reconnect. They will need to reset the gateway from their end. good Luck.
Sep 07, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Do not have cd to set up model no.dx-e402
You can set it up with the manual:
http://www.dynexproducts.com/t-product_documentation.aspx
Mar 27, 2010 | Dynex 4-Port Ethernet Broadband Router...
My network settings don't match wireless router.
First Option :
Connect your computer directly thru Router LAN Port. now
If your Computer is configured thru Static IP address then change it get IP address thru DHCP. and Re start the computer. So it will get IP address from Router and you will be able to access Router Admin thru browser.
Second Option
You will have to reset router to factory defaults. To do that ; There will be Tiny Hole or Switch on Router Back side or front side.
Using strait Paper Clip wire ; Put in that wire in that hole and give very light pressure for 5 to 10 second. Make sure that router is Power ON.
So your router will be resetted to Factory default. Now reconfigure it
Mar 09, 2010 | Netopia (3347NWG-VGX) Wireless Router...
I have no home network with uverse. How do I fix
hello Shopostamp
you need to set up a wireless network. From a wired connection to your router just open your web browser" 192.168.1.1 " type admin for user name and password (default) from here you can see a tab to set up you wireless network. you can read the full installation manual here.
Feb 26, 2010 | Gateway Wireless-B Router (wbr-100)
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
Home networking with uverse
Try to run the Windows Network Wizard in each computer on your network.
Mar 04, 2009 | Gateway Wireless-B Router (wbr-100)
I want to use 2 wire ATT UVerse -- BUT NOT WIRELESS
the 2wire att uverse router, does not broadcast wireless signal if there is no wireless computer connected to its network. regarding the unchecking of the ssid, it will only hide the network name of your router, but technically, if a computer will try to connect to your router, it will still "send" wireless signal to a computer within its range.
you do not have to worry about the wireless signal being sent, if nobody connects to the router via wireless cionnection.
Jan 11, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Gateway At&t 2701hgv-b 2wire Hi Speed Internet Wireless Modem Router Uverse Att Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
