Question about Nordic Track NordicTrack Treadmill, A2550
My NordicTract bike is saying checksum failed what could be wrong with it
How do i fix checksum error on start up zoomstorm 10 270
That is indicating somethng has failed in your rom memory. either reprogram or replace it.
Nov 23, 2014 | Computers & Internet
Computer will not load windows OS. it will say bios rom checksum error on a compaq presario SR1365CL
This is a typical sign that the CMOS battery (the coin-shaped battery on the motherboard) has failed & needs to be replaced. After replacing the CMOS battery, you will need to boot into BIOS & save CMOS settings.
Jul 13, 2011 | Computers & Internet
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
Flash test Fail! wChipID = 0x80 - Disimage Info length = 3600000 checksum = 4d8323a7 -starting counting ...................... ................... checksum = 4ad32f1b Test Fail! Press any...
- Disimage Info
length = 3600000
checksum = 4d8323a7
-starting counting
checksum = 4ad32f1b
Test Fail!
Press any key to continue...
Do not work FM,TV,Camera after using wrong rom
Help please with gsmart i120
Merlinwarwar@gmail.com
Feb 16, 2010 | Gigabyte g-Smart Smartphone
Help
Greetings,
When you upgrade your computer to Windows XP, you may receive an error message that is similar to one of the following: C0000221 (Bad Image Checksum)
-or- STOP: C0000221 - Bad Image Checksum in ModuleName
-or- STOP: C0000221 - Bad Image Checksum. User32.dll is possibly corrupt. The header check sum does not match the computed check sum.
Please go through the below mentioned link:
http://support.microsoft.com/kb/326687
Sep 20, 2009 | Microsoft Windows XP Professional for PC
File header checksum does not match computed one. ???
You have one or more critical corrupted file/s which prevents the laptop from booting up.
To get the laptop operating again, you need to insert the Windows Vista CD and do a Repair and if this fails you need to install Vista again.
May 05, 2009 | HP Pavilion dv6000z PC Notebook
Hard Drive will not boot in Compaq Presario C700
BIOS checksum errors occurs when either the BIOS chjp is faulty or most likely the BIOS battery is nearly flat and the stored info changes and doesn't match the checksum info.
Replace the battery with a new one, leave the battery out for 1/2 hour before inserting the new battery. The BIOS will be reset to the default settings, you need to configure it again eg, datr and time etc.
Feb 22, 2009 | Compaq Presario C700T Notebook
CMOS checksum error
rahul23petit
"CMOS" checksum error default loaded" means ur mother board cmos battery fail (which is locate at mother board), to solve this problem replace it by new one (u can buy it form any computer accessories shop). all oher problem happen for it.
Jul 06, 2008 | EliteGroup BKi810 Motherboard
Nordic Track NordicTrack Treadmill, A2550 Logo
22 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
