Question about EdgeStar 2.0 Cu. Ft. FastDry Ventless Washer Dryer Combo
Error message 3R on Edgestar washer/dryer combo - what does it mean?
Does anyone know? This happens during the drying cycle.
Pump stops working during drying cycle
yes you are right it is the problem of dryer pump you have to check that pump and if neccesary replace it.
Thank you
Dec 07, 2007 | Supra SW5L30D Front Load Washer / Dryer
HI would you what know what error code Er13 is?? on a Logik L614WD13 washer dryer?
Feature : Error Code-control panel display "Er13"
  • Answer : Reason:Drying heater element error. Sometimes caused by to much load during the drying cycle. Washer dryers can only dry half the wash load.
Nov 03, 2014 | Washing Machines
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Edgestar e30
E30 is a door locking failure. The unit attempted to lock the door several times without success. First, make sure your door is closed firmly. Check for anything that may be blocking the door latch. Check that the latch is aligned to the door lock. Unplug the unit for 30 minutes to reset the electronics. If the unit still does not lock, please contact Edgestar at 800-297-6076.
Dec 06, 2013 | EdgeStar 2.0 Cu. Ft. Ventless Washer Dryer...
My 1988 washer/dryer combo Model LSG1000 is showing an E2 code for the dryer. Do you know what that means?
sounds like she might be stuck in an econemy mode ,if its digital try to find its reset button,sometimes very small and out of the way,might have to look up the manual on the net to find this tiny button ,good luck
Feb 12, 2013 | Maytag Dryers
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Jan 06, 2007 | Hotpoint Aquarius WD63 Front Load...
EdgeStar 2.0 Cu. Ft. FastDry Ventless Washer Dryer Combo Logo
64 people viewed this question
Top EdgeStar Dryers Experts
Are you an EdgeStar Dryer Expert? Answer questions, earn points and help others
