My smps fan not roatating. what happens if it is not roatating?
    Master:
  • 752 Answers
It may be that you PSU will overheat. It depends on the features of your PSU as to what the consequences of this are.
Some PSUs are equipped with a thermal cut-out in which case your PSU will simply turn itself off. Others will overheat, and internal damage to components will ensue, and your PSU and possibly your computer will cease to function (permanently). Your PSU may just catch fire in the worst case.
However, it may also be that your SMPS fan is thermally activated and only comes on when the PSU temperature is greater than some threshold; this is a design feature of the PSU if it is present. Some fans are equipped with a speed con troll that links the speed of the fan to temperature of the PSU. See you PSU details to determine which of the it may be. If it is a Zalman brand PSU, most likely it has a themally controlled fan. This feature also has propriety names such as "Silent Fan Technology" or "Whisper Fan"
18.April.2014
Posted on Apr 18, 2014
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
I trun the pc on and nothing happens
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 26, 2011 | Acer Aspire™ T180 PC Desktop
Hi my hp pavilion laptop DV5000 on start up has black screen and one long beep then 3 shot beeps then one long beep and another 3 short beeps. The lights stay on but nothing happens. The pc has been...
Feb 26, 2011 | HP Pavilion M9040N Elite Desktop PC
Seams like fan not working
if the fan is not working first you have to test the smps remove the smps connector from the motherboard and short the green and black pin it he smps fan is working then the smps is fine coneect the smps connector to the motherbord and switch on the computer still not working then remove the four pin connector from the smps and restart your computer if irts working the problem is in your motherboar
Dec 30, 2010 | Dell (6F858) Cooling Fan
Shutting down, happens about once a week Removed
Seems like its overheating. Check if fan is working properly. Plus give the fan assembly including the one in the SMPS a thorough cleaning with the help of a vacuum cleaner.
Dec 04, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
I am able to turn on cpu but the monitor is not displaying it. Power is coming, Two fans are running in C.P.U. Some times fans not work. Kindly suggest me why this happens and give the solution for it.
093aba5.jpgYou have a problem with your SMPS. Kindly send your SMPS to a repairing shop. If the guy suggests you to buy a new SMPS then there is hardly anything that u can do instead of buying a new one. I had the same problem once had to replace the SMPS as even after two repairs the SMPS wasn't working properly. There is a prob with the switching regulator for sure if your monitor works perfectly then.
Sep 24, 2010 | Computers & Internet
I went and bought a new power supply today. because i noticed my power supply fan was not working. but my new power supply is not working nither
Sometimes this happens. A newly procured item also does not work. In order to check that your smps is working or not just unplug every output from it and give power supply to smps and check whether the fan is running or not. If not then smps is faulty.
Apr 21, 2010 | Computers & Internet
How to replace exhaust fan on Compaq Presario SR1103VM
what kind of pc are u using plz? is the maain case with screws
Apr 02, 2009 | Computers & Internet
Color Printer fan error
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan. The firmware solution from Samsung disables monitoring so if the fan stops the printer will keep working. Thankfully, it's not physically hard to fix this issue though and can be done by removing 9 screws and using a little oil.
I've actually posted a step by step guide to fix this here.
Mar 25, 2008 | Samsung CLP-600N Laser Printer
Pc won't power up
Dear Buddy117,
What i have understand that u r Motherboard getting the power supply but i want to know that is u r SMPS power supply fan rotating or not if no then u have to change the SMPS if it is ratating then u have check the power switch in u CPU cabinate is that power switch wire properly connected to the motherboard if it is connected then check wether it is connected in right place or not i hope this information will going to help you.
Regards,
Bittu_8
Feb 14, 2008 | Foxconn 865A01-PE-6EKRS Motherboard
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
