Question about Sam4s SAM5215 Er-5215M 1
Reset to Factory Settings
I started initiating the communication between ER-5215 and my PC when it asked me to add paper, which I did and then got " Cover Open Err". If I switch the key to other position I get "Sequence Error". The register doesn't respond any more, just make a continuous sound... Is there a way to reinitialize the register so I can re-attempt to connect to my PC and start programming? Thanks for your help.
  • Sam4s Expert
  • 591 Answers
Just press down the cover on the printer until you hear a click sound then go ahead
Posted on Apr 14, 2014
How can I get a second hand Mitel 5215 to accept an IP address?
Your phone needs an IP address in order to communicate. Normally, it asks a "host" for that IP. You need to be connected to the internet for it to connect to the normal host, and your router should be willing to give it that IP address. "DHCP" is how devices ask for and get an IP address.
May 11, 2015 | Mitel 5215 IP Phone
Need to reset a used Sharp ER-A220 to factory settings
Hi, type in search engine ER A220 Reset
loads of info. Good luck.
Mar 02, 2014 | Computers & Internet
Factory reset please help me to reset my Mitel
Reboot phone and hold down the down arrow key. This will put you in the programming of the phone. Use * and # to toggle thru until you see default . Then follow screen to save and reboot
Sep 18, 2013 | Mitel 5215 IP Phone
Printer does not reset
NVRAM initialization/cold reset
NVRAM initializer sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initializer resets the following:
! all menu settings to factory default values
! factory settings such as formatter number, page counts, factory
paper settings
To perform NVRAM initialization
1 Turn the printer off.
2 Press and hold down the GO button.
3 Turn the printer on and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
4 Release the GO button.
5 The printer LEDs will begin cycling. The NVRAM-unit process will run until the printer is in the ready state.
Or download the service manual here ..
http://www.google.com.sa/search?site=webhp&source=hp&q=hp+laserjet+1200+printer+service+manual&oq=+HP+LaserJet+1200+Printer+service+&gs_l=hp.1.0.0j0i22i30l6.200423.206442.0.207913.10.10.0.0.0.0.763.3187.0j3j2j3j1j0j1.10.0...0.0...1c.1j2.9.hp.QNDAx6nGCA0
Apr 18, 2013 | HP LaserJet 1200 Printer
Sequence error warning comes up on display, as soon as i turned on my ER-5215 M cash register, how to fix it?
I have a cash register Model# ER-5215 M there is a message on the screen as follows: Reg. PBAL how do I fix it.
Jan 21, 2013 | Computers & Internet
Whenever I print my document, it doesn't exist the document I want to print but many strange symbols appear on the printed paper, how can I solve this problem?
Cold reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM inititialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
Note If an HP Jetdirect card is installed, remove it before performing a cold reset. Otherwise, the procedure will also reset all the HP Jetdirect settings as well as the printer settings.
To perform a cold reset
3 Turn the printer on, and continue to hold the GO button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED will turn on.
Note If both the Attention and the Ready LEDs turn on before you release the GO button, you must start the procedure again with step 1.
5 The printer's LEDs will begin cycling. The cold-reset process will
run until completion, and the printer will return to the ready state.
If not work, tris this
CAUTION Only perform the following procedure if absolutely necessary.
Performing an NVRAM initialization resets some parameters that cannot be restored later.
NVRAM initialization sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initialization resets the following:
  • all menu settings to factory default values
  • factory settings such as formatter number, page counts, and factory paper settings
3 Turn the printer on, and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
Jul 30, 2011 | HP LaserJet 1300 Printer
My nephew's original xbox will not turn on it just flashes green and orange around the power button
If your system has had an internal system error (three lights) and is now having issues recognizing controllers, remotes, and/or personal music player's, the only currently know solution is to rerun initial setup.
Rerun initial setup
Before trying this, it's highly recommend that you remove all hard drive and memory cards. Once you've removed all hard drives and memory cards, navigate to the systems tab in the main menu and select the "Initial Setup" option. Once you select the option, it will ask you if want to run the initial setup that occurred when you first started your console. Say yes and it will do its thing. When it asks for a memory card/hard drive, just decline and it should be done. You should see the default dashboard screen as confirmation that it did, in fact, rerun initial setup.
Resetting to factory defaults / resetting parental locks (unconfirmed)
This was posted on the xbox-scene forums and might work only with older versions of Xbox 360 dashboard.
Press the following key combination
  • Left Trigger, Right Trigger, X, Y, Left Bumper, Right Bumper, Up, Left Bumper, Left Bumper, X
This should give you a dialogue asking whether or not you want to reset your system to factory default settings.
Reset Xbox 360 video settings
While the Xbox 360 is starting up, hold Y and Right trigger. This will cause the system to reboot and reset the video settings.
Nov 21, 2010 | Microsoft Xbox Console
How do i get windows vista basic to its factory settings?
Not sure what your asking here but I think you might want to do a factory reset, when the computer starts is there a promt to hit a key for recovery, if there is press the key and recovery console will start, hope this helps. dont forget to back up before recovery is initiated
Nov 15, 2010 | Computers & Internet
5215 5220 and 5224
The Mitel IP phone downloads its firmware from the 3300 ICP on startup, You need to spesify what the phone is doing, ie does it start up at all or is the phone Dead,
If the phone does start it might have the wrong settings in the phone preventing it from finding the 3300 ICP, There is a Default to factory setting by interupting the phone on bootup.
Dec 07, 2007 | Mitel 5215 Corded Phone (50002817)
Sam4s SAM5215 Er-5215M 1 Logo
225 people viewed this question
Top Sam4s Retail Supplies Experts
Andrew Taylor
Andrew Taylor
Electroboy
Electroboy
tomferryman
Level 1 Expert
Are you a Sam4s Retail Supply Expert? Answer questions, earn points and help others
