Have Epson Pro 7890 printer when it runs message appears ( 1A39 ) So to solve this message?
Fatal error
    Sergeant:
  • 269 Answers
Take all paper out uninstall software and reistall
Posted on Apr 13, 2014
Epson 11880 error code 1135
By doing a Bing search, it shows that error code means to replace print head. If you purchased it new, it shouldn't need a cleaning. You could try removing the print cartridge(s), then put them back in, making sure they are seated correctly, then restart the printer.
May 22, 2017 | Epson Office Equipment & Supplies
Fatal error 1a39
Fatal error 1a39 - The description says:
"Service Call Error
Code: 1A39
Category: Hardware
Error Name: Head Error
Cause:
• Connection failure of the HEAD FFC.
• Electric parts or components are damaged due to improper HEAD FFC connection such as connecting it at an angle.
• The drive circuit in the PRINT HEAD is damaged.
• The fuse of the MAIN BOARD has blown.
Check Item:
Is the HEAD FFC connected properly without being connected at an angle and any abnormalities such as peeled terminals?
Remedy:
1. Replace the HEAD FFC. (See P.127)
2. Replace the PRINT HEAD. (See P.126)
3. Replace the MAIN BOARD. (See P.111)
As a point of reference, your three manuals are here (link below), which is where I found this info. (See the first manual listed - in the chart on page 53: Table 2-2). Good luck!
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=220056&prodoid=63096219
Aug 20, 2014 | Epson SureColor T-Series T3000 Inkjet...
Epson 7900 - 1A39 - Head error
1A39 is a print head failure. The head needs to be replaced although it is very expensive and you are better off buying a new printer.
Feb 06, 2014 | Epson Stylus Office Equipment & Supplies
Getting message error 0001000C on Epson Stylus Pro 9800 right after is done printing. The next print after message (after i turn off and on the printer) appears with double image on some areas.
its a carriage home position sensor error u have to clean the sensor and the stip guide which has been attached on carriage... its due to dust on sensor.
Oct 17, 2013 | Epson Stylus Pro 9800 InkJet Printer
EPSON 11800 Having an Error code: 1A39
hi the same for me 1A39 on a 9900, i check everything nothing else to do than to change the print head, in fact it's an active signal send by the head it self.... mean that it's defect ..........good luck ! good forum for help on epson printers : http://www.luminous-landscape.com/forum/index.php
Jun 15, 2012 | Epson Stylus Pro 11880 InkJet Plotter...
How do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
tomas
how do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
Solve this problem:
Aug 02, 2010 | Epson Stylus Pro 9600 InkJet Printer
Epson cx 2900
If the error is fatal then there is NOTHING you can do at home to sort the problem out. If Epson are refusing to repair the unit because you have repeatedly used non genuine ink then you can try and take them to task on the legality of that decision (depending upon consumer law in your area) but the chances of you getting it sorted without costing a fortune are slim to none.
There is an error which shows up in the status monitor as MAINTENANCE error and this can fixed relatively easily. It's symptoms are similar. However, a fatal error is generally just that - Fatal - and there is nothing the home user can do as this generally requires parts fitting.
Your non genuine ink is almost certainly NOT to blame for the fatal error though. At worst the **** ink you use will clog nozzles and may even ruin the print head by clogging all the nozzles and causing only blank pages to be produced. BUT can you prove this to Epson in court?
My advice - bin the printer and replace it with one from a manufacturer who appears to give a damn about their products and customers as much as their fat pockets!!
May 26, 2008 | Epson Office Equipment & Supplies
345 people viewed this question
k24674
