Central heating randomly turning on
A couple of months ago we had a prolonged power outage (nearly 8 hours). When the power came back on, the ducted central heating fan turned itself on and ran for a couple of hours, even with the thermostat turned off at the wall. Since that time the heating fan turns on and off randomly for short periods of time. A plumber looked at the unit and found nothing wrong and so replaced the thermostat (from a dial to a digital). Today the fan turned on and off again, the new thermostat digital display appears to be flicking on and off without being touched and it is switched off. I have checked other forums and no the roof space is not hot (and has not been since this problem started) Can anyone suggest what is wrong?
    Sergeant:
  • 269 Answers
New thermalstat
Posted on Apr 13, 2014
  • 1462 Answers
SOURCE: central A/C motor blade turns all the time
it is just possible that an air draft thro rhe fan blades is turning the motor. to check, disconnect the motor and see if it still turns. disconnect from mains before doing this
Posted on Apr 03, 2007
SFroese
  • 141 Answers
SOURCE: central air unit problem
Check inside that breaker box for fuses.
Posted on Sep 06, 2008
  • 15 Answers
SOURCE: Central Airconditioner Heat Pump Weather
It sounds like you might have a short in the wiring that goes from the furnace (inside part) to the condenser (outside part). Follow these lines by hand and check to see the wire isn't damaged and shorting out.
Posted on Sep 19, 2008
  • 340 Answers
SOURCE: fan wont turn off
the control board is bad safety feature of carrier board . Tom
Posted on Jun 30, 2009
kingbrizzle
  • 407 Answers
SOURCE: Carrrier Central heat and air. Model 38CKC042300,
Unfortunately no, this is one of three things.
1. Compressor is worn and is starting to pull to many amps to operate. Can possibly be fixed by putting a hard start kit on the unit, but will have to be done by a technician.
2. Compressor has an internal short and will have to be replaced.
3. Fuses bad or under sized. Max fuse size is stated on information plate on outside unit.
Sorry to hear about your troubles and hope you can get it fixed soon!
Posted on Aug 15, 2010
Ovens work fine . .ONCE ! Then buttons do nothing until you turn off the wall breaker for an hour. Then the oven works ONE time again.
Tom Sh, you own every kind of appliance, or you are attempting to be a repairman with free advice from Fixya?
Replace the touchpad. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Ovens Ovens
Reset after power outage
Assuming this is a 220 volt dryer, are both sides of the breaker on? It should not blow only one side of the 220, but worth checking.
Jan 26, 2014 | Kenmore Dryers
I have a coleman heater (central heating/A/C) Excel energy had a 2 hour power outage this morning unplanned and now I am trying to reset the thermostat so the heater will come back on) I had to reset the...
Hello, You may have this already solved by now but here goes. If your unit was running at the time of the power outage, you may have a limit switch kicked. This would cause your main blower to run non-stop with no heat. Gas furnaces has a main limit mounted on the wall of the heat chamber. This one should reset automatic when it cools down. Then you have a limit (maniual) reset on the blower casing. This is a small round device with two small wires coming off of it that goes toward the main board. If you can find this limit switch it will have a small button in between the two wires where they attach. Push in this button, if it clicks it should light the flame.There may be another limit on the burner casing. Try pushing this one also. When the power goes out when the flames are on this will build a lot of heat up near the blower causing this limit to kick off. Hope this helps.
Feb 03, 2011 | Coleman Propane Forced Air Heater...
My hp media center pc worked fine untill about two months ago when it just shut off on me after a couple hours of use. The power button was flashing blue and orange and the only way to turn it back on was...
This could be a heat issue. If the PC is on the floor, it will draw large amounts of dust and dirt into the machine via cooling fans. Check this link to reduce heat inside your case and on individual components.
Look at the rear of the PC - near where the power cord connects to the power supply. Locate the LED lamp and compare to this link for HP's document to assist troubleshooting the power supply.
Hope fully, one of these options will be a solution for your problem. Good luck!
Jan 11, 2011 | HP Media Center m1270n (PP132AA#ABA) PC...
The power went out twice in a one hour period a couple of days ago. After the second outage, my monitor would not come back on. Unfortunately, I had removed it from the surge protector to plug something...
1) Have you checked the fuse in the mains plug ?
2) There may also be a secondary fuse, inside the monitor (don't as me how to dismantle it, all I know is carefully) on the main cct board near to the power in socket.
Mar 14, 2010 | Acer AL1916W 19" LCD Monitor
Totaline Thermostat either P/N 474-0100 or -0220
The power outage probably caused the thermostat to go back to factory default settings. You need to go through the advanced setup procedures in the owners manual on page 6. This will allow you to turn the heat pump back on.
Oct 05, 2009 | Heating & Cooling
My dell vostro turns off randomly after one hour or more of idel
Hello, it may possibly be a heat problem. If it reboots and runs fine for awhile and then turns off it sounds like it is over heating. A couple things to check out are make sure the cooling fans are running if present, also make sure the tower is well ventilated and not full of dust. One of these could be your issue. Good Luck!
Ryan
www.cobaltsys.net
Oct 01, 2009 | Dell Vostro 200 Desktop Computer Intel...
Kenmore Ultra Bake GAs oven
Here's a link: http://www3.sears.com/ put in your make and model and you can order a manual. Good luck!
Jul 19, 2008 | Ovens
Vulcan CX Central ducted heating. RE: Following a power outage the control panel does not respond, I have checked the pilot light and it is still on. I need to know how to reset the time and get it to...
The control panel gets its power from the central heating unit's power point. Try turning the power off outside at the powerpoint next to the ducted heating unit and try turning it on again after a few seconds, see if it resets
Jul 06, 2008 | Heating & Cooling
My Whirlpool Clean Touch electric dryer is not drying clothes very well. It is not getting real hot, and it takes two cycles to get most things dry. Towels and jeans take part of a third to dry. I clean...
IF YOUR DRYER HEATS AT ALL, BUT WON'T DRY THE CLOTHES, 99 PERCENT OF THE TIME THERE IS A RESTRICTION IN THE AIR FLOW. PULL THE EXHAUST OFF OF THE BACK OF THE DRYER AND DRY ONE LOAD. IF IT DRIES O.K., THERE IS A RESTRICTION IN THE DUCT WORK.
CLEAN OUT THE LINT FROM THE DUCT WORK. IF THE DUCT WORK IS FLEXIBLE MATERIAL, REPLACE IT WITH RIGID 4 INCH METAL DUCT.
Apr 16, 2008 | Dryers
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
