Question about Sharp LC-32SB24U 32 in. LCD TV
Need to set lc input on tv
Need to set up with wireless box
  • Sharp Master
  • 10,263 Answers
2 Suggested Answers
vlado_ondr
SOURCE: I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
S12 Mini Android 4.0 Mini PC Google 2,3 Box TV WIFI 1GB DDR 4 GB Nand Flash
I have android tv box after the first switch off my screen froze inscription ANDROID-lit after several hours of no change
Can anyone advise me how do I restore system
thank you for your help
Posted on Mar 14, 2013
Where is the HDMI connection on my Sharp LC-46SB57? I installed X1 and cannot get picture. Sharp Input 1,2&3 are grayed out but Inputs 5Roku & 6blue ray work.
The X1 box acts like a set-top cable box. The HDMI output can be connected to any HDMI connector. There are three HDMI connections on the rear of the set. You have the Blu-Ray connected to one of them, Input 6. You should have no issues with connecting the X1 to either Input 7 or Input 8. There is no specific "TV" HDMI connection. You simply use the remote to select the HDMI port that the X1 is connected to.
Nov 18, 2015 | Sharp Televison & Video
HOW DO I CONNECT WIRELESS KEY BOARD TO MY TV. SHARP MODEL LC-60LE650U
Does tv have usb input? Usually usb is for mass storage only, as the tv wont know the driver for a keyboard, but you can try.
Sep 02, 2015 | Sharp 60" LC-60LE650U AQUOS Full HD Smart...
Trying to set up my new elements tv with a uverse wireless box. Did a channel scan but still can't find any channels. Help please!!
Is this a high def tv? Are you using an hdmi cable, component cable(red green & blue) or a low def coax cable to connect the tv? If coax, the tv needs to be on channel 3 or 4. If hdmi or component cable is used you need to change your input on the tv with your remote to the matching input you wired it to. The uverse stb (set top box) changes the actual channels once you have selected the correct input.
Jun 26, 2014 | Televison & Video
Sharp LC-32sb24u hdmi not working
You have to tell the TV which HDMI input to use. ie you should be able to press a button on your remote to do this. On my tv we can choose between 4 different HDMI inputs via the remote.
Dec 23, 2013 | Televison & Video
Power and OPC blinks, TV will not change Input modes
Try removing set and or a box if used from power for several minutes.
Dec 23, 2012 | Sharp LC-46SB54U LCD TV 46 inch Class,...
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
HOW DO I GET THE BLUE BOX ON MY SHARP AQUOS LCD TV TO STOP POPUP
This happens when you are connecting with a coaxial cable. If possible you will need to connect your set top box to the television with a composite/RCA cable and watch tv on input 2 instead of on input tv.
Mar 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Dec 29, 2006 | Sharp LC-37D4U 37 in. LCD Television
Sharp LC-32SB24U 32 in. LCD TV Logo
21 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
