Question about Lakewood 633 Compact Heater
Alarm comes on
Fan will not come on, so the alarm system comes on, what is wrong ?
  • 625 Answers
Need more information
Posted on Nov 04, 2007
My fridge is about 2yrs old I need to know how to turn of the alarm when the door is open. When I am cleaning it. I cleaned it two days ago and now it is making a terrible noise.
The alarm tells you that something's wrong something's not cooling properly or something's wrong with the defrost system if you left your doors open for quite a while it will create ice around the fan blades and that could be your noise problem. d
Disconnecting the power to your refrigerator opening the doors for about 12 hours and let it manually defrost will usually solve the problem.
Appliance 911 Sea Breeze
Jul 24, 2016 | Fisher and Paykel Refrigerators
What is the type and parameters of the internal cooling fan
The type of fan can be very different between two similar UPS.
The easiest way is to open the UPS and watch for.
Some UPS requires exactly the same fan, and if they take too little or too much current UPS think that it is wrong on the fan and alarms!
May 28, 2014 | MGE Computers & Internet
ABS disabled
abs dont beep. alarm does. you will need to check this. abs alarm and ecu and immobiliser etc are linked. I.e locked to you make and model and serial code. alarm can beep and knock out one of the units. sometimes if this fault happens it can be a simple problem like the external alarm unit has its own power but is charged from the main battery. these can go wrong, will beep. you can disconnect this part of the alarm. there is the back up alarm part. I would check this.
Feb 23, 2014 | Cars & Trucks
I am getting a second alarm when the first lock alarm is pressed in my wingroad car and when you open the doors the alarm is not coming on
If you open the doors when the alarm is armed and, the alarm does not trigger then, you have the wrong door trigger wire connected. If you were to list the year, make and model of the vehicle I could direct you to the proper wire and location.
Jun 28, 2013 | 5601 1Way SuperCode Security and Remote...
Alarm on my 2002 F250 started going off all of a sudden while parked and unlocked. the only way I could make it stop was disconnecting the batteries. what's wrong with my truck?
First, take the battery out of your key fob. All of them. Then hook the battery back up on the truck. If alarm doesn't go off, put battery in one fob. Check it out, all functions. Then check the other one. If alarm goes off when you hook truck battery back up, look for a shorted switch to whatever you alarm monitors and sets an immediate alarm when the switch is closed (or opened). If you still can't locate the reason for the alarm, consider replacing the alarm system, but not before you come back here and tell us what happened.
Sep 17, 2012 | Cars & Trucks
Alarm sounds coming from the computer
hi I think it has to do with Asus AI Bios. It usually informs you when something wrong with your hardware. I had issue when it was sayin wit strange computer voice that CPU fan has failed! May be your PC is overheated when it makes this sounds!
May 21, 2010 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
Freezer Temp Alarm
Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
Sep 06, 2008 | Freezers
Carrier 38CKC042 Air... Problem--Alarms for 60 sec. when the fan blows
Where does the alarm come from? Is it a beep noise or a siren noise? Please let us know. The reason I ask is because this is not something I have ever ran into before. Based on the model number you provided I have determined your unit to be a typical split system A/C. I do not see even an option to install any alarms for it.
Maybe it is wired in series with another alarming device like. Maybe it is not an alarm at all but a bad bearing in the motor causing an alarm sound.
Jun 25, 2008 | Carrier 38CKC042 Air Conditioner
Lakewood 633 Compact Heater Logo
95 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
