Question about Sylvania Sgpd432 4.3 Touchscreen Portable Gps Navigation System W usa
My sgpd 432 blows the fuse every time I plug it to charge or to use it. I need to get it fixed a.s.a.p. as I use it for my work
  • 22 Answers
Did you try another charging cable/device, or connecting cable to computer (if relevant) !? can you change the inner battery (probably not) ?
if you did, and prob remains, then your device might be dying, and needs to be fixed/replaced :-(
Posted on Apr 13, 2014
Fix tv blowing fuses
when replacing fuses in a device....if, when you next apply power to the device and it immediately blows the fuse again : Do NOT put in anymore fuses. It is time to visit a TV repair shop.
Oct 30, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Samsung nc10 charger blowing fuse?
The charge adapter is faulty. You need a new power adapter for your model Samsung notebook.
May 20, 2013 | Samsung NC10-14GW Notebook
My aquabot keeps blowing fuses in or out of water
may be waterlogged. internal seal failed and its shorting out..
Aug 06, 2012 | Pool & Spa
Spark plug gap for my 2001 ford ranger 6 cyl. 3.0 motorcraft platinum sp-432
Hello motokid40: My name is Roger and I will help you. The correct plug gap for the sp-432 plug is 0.044 in. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Mar 22, 2010 | 2001 Ford Ranger Regular Cab
Air conditioning and blowers not working, fuse blows immediatley after changing. there was a clicking noise heard before fuse blew. No display on dash unit. (2000 passat 1.9TDi Sport)
Try unplugging the blower resistor, located under the passenger side, under dash area, put a new fuse in and see if the fuse opens (blows). If it does not blow then unplug the blower located in roughly the same are and plug the resistor back in if it blows then it the resistor if not it's most likely the blower motor.
If the fuse blows when both resistor and the motor is unplugged the you need to unplug the a/c head unit and see if it still blows(open fuse)
Hope this helps
Mar 17, 2010 | Volkswagen Passat Cars & Trucks
My charge port in my 2006 cadillac cts repeatedly blows the fuse. How can I fix this?
Does the fuse blow every time you plug something into it? I guess what I'm getting at is it possibly your phone charger only, or does the fuse blow when someone else plugs thier charger in (different charger)? I guess if the fuse blows, no matter what you plug into it, I would suspect the charge port itself. Does it seem like it's loose in it's mounting bracket? You may have to replace the port.
Jan 03, 2010 | 1995 Cadillac DeVille
My sony receiver tuner wont turn on. It was working fine yesterday now it wont power up. The fuse near the plug wire inside is good. Any suggestions
Fuses almost never go bad something causes them to blow. Even when a blown fuse is found in electronics just t replacing it can cause more damage if something caused it to blow, a repair person looks for bad parts before replacing a fuse. Only microwaves are known to blow fuses and replacing the fuse fixes it. About the only thing that people can do is unplug a short time and try it again. And need i say is the power outlet ok.
Nov 03, 2009 | Audio Players & Recorders
I put my 87 4runner in reverse and it blows the 15A engine fuse
Hello there:
I would first refer to the owners manual to make sure that the fuse that is blowing is of the right amps also check the fuses under the hood too. than i would check to see if there is any shorts anywhere and get them fixed. You can also take the car to autozone and have the free diagnostics done on the vehical ok?
hope that htis has helped out some.
best regards mike
Aug 25, 2009 | 1987 Toyota 4Runner
RAV4 Charging Cell Phone Causes Fuse to Blow
have never heard of a vehicle that can't be used to charge a cell phone but if that's what the dealer said, they usually know something about the vehicles they sell. i can suggest a work around but it might be you won't like it. you can buy a 12v jumper pack, it's really just a battery in a plastic case that can be used to jump your regular 12v car battery in the event that you can't get the car started from the regular battery under the hood. they are available in a few different sizes, they have them at car parts stores and dept. stores, you plug it in at home and it charges up overnight, then take it in the car with you just in case. every one of these that i have ever seen has a 12v outlet on them. some of these are quite heavy but you don't need a big one and you probably won't need to charge it more than once or twice a week just running a cell phone charger off it. i will admit that it is not as convenient as plugging it into your car but it won't blow a fuse and i'm pretty sure it would work. hope that helps
Jun 10, 2009 | 2001 Toyota RAV4
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Sylvania Sgpd432 4.3 Touchscreen Portable Gps Navigation System W usa Logo
43 people viewed this question
Top Sylvania GPS Experts
Martin Murray
Ngoro
Ngoro
k24674
Are you a Sylvania GPS Expert? Answer questions, earn points and help others
