Question about Pyle Audio Players & Recorders
When i use the aux. mode the right speaker does not work but the left does, but when i use the radio the right and left speakers work just fine.
)PLR44MU)this model specifically
    Problem Solver:
  • 8 Answers
I just looked this particular model up on several different sites. Ebay is offering refunds on them. I found other sites that went into great detail on this model. Some people had to remove face plate then the problem seemed to get better. If your aux cable is not new. As a DJ I would suggest putting a light coat of WD40 on a paper towel or napkin makes sure just very light coat on cable insert and twist see if port is dirty by wiping when you remove aux cord. DO NOT re connect for play until allow time to dry. Others can't get SD to work. You also may want to double check the wiring on right side just to make sure there is not a break of crack somewhere between aux and right side connection. That's my basic troubleshooting process.
Posted on Apr 13, 2014
techman
  • 3130 Answers
SOURCE: Left Speakers not working on A or B channel
Have you tryed yet to switch the right speaker where the left one is? If it works then you know the speaker is bad. If you move the left speaker over to the right channel and it works and sound now comes out of the left speaker, you know there is a fault in the amp somehwre. If your not a tech and have not had any solid state equipment repair experience, then your going to have to have the amp serviced by a trained tech.. Good Luck
Posted on Oct 30, 2006
  • 319 Answers
SOURCE: both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Posted on May 01, 2008
kevin000
  • 1847 Answers
SOURCE: Left front main speaker level drops after being on for a few hours
Run the speaker test mode :
While running the speaker test tone to balance your speakers, you cannot adjust the balance of the Main speakers independently. The speaker test allows you to balance the sound (dB) levels of the Center speaker, Rear Left, Rear Right speakers to match the level of the main speakers. So, the first thing you do is press the [TEST] button on the remote. Next, adjust the [MASTER VOLUME CONTROL] until you can adequately hear the level from the main left and right speakers. Then, as the tone travels clockwise to each speaker, listen carefully from your main seating position in the room to determine which speakers (if any) need to be adjusted in level (either up or down) in order to balanced the sound to the main speakers output. Then adjust the Center, Rear Left or Rear Right speakers accordingly until the proper balance of level is attained. If you would like to change the level between the mains, you can use the [BALANCE CONTROL] either located on the front panel of the receiver or in the Set-Menu. A common challenge people have is that they try to adjust the main speakers to match the center or rear levels. If your center speaker is louder than your mains, You cannot adjust the main level up, you need to adjust the center speaker level down. All speakers need to be adjusted to match the main level.
Posted on Jul 05, 2008
SOURCE: Pioneer SX-750 Old School Need Help
Check the speaker wire. Sometimes it can just be loose in the terminals and cause distortion. I have had the problem before.
Cheers!
DellMan94
Posted on Jan 12, 2009
SOURCE: Speaker output
Yes, there are relay type switches associated with those outputs. Your RX-V1 is not dying.
Just plug a pin plug in and out of the dead channel to bump the switch. You will hear the speaker
come on. If it doesn't come on,do the plug jack in an out of the pre out again. It will come on.
You can use the test tone to check all channels and rebalance volume levels. You are making the
pre out connect to its power amp. It seems the problem got better when activating those switches. Most likely a cleaning issue. You can also jump the mains and center, and there is also
a modification to jump all channels. I bought my RX-V1 very cheap because of this and love it.
Of course outboard power amp would solve all, but getting this reciever to connect to it's own
power amp has been thrilling as far as bang for the buck. I do use the front effects also, and like
them. It may seem like a pain, but it is worth it to get those channels going.
Posted on May 31, 2009
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
Replaced Headunit with after market one, but now the dash lights don't work, Fuses are fine, everything else is fine. Car is 1999 Mazda 323
Hi, there is a factory wire (red with a black stripe) in your car for illuminating the stock radio. This wire is not to be used in an aftermarket radio, so you need to make sure it isn't connected and also isolate and bare wire with electrical tape. Please let me know if you have questions, and thanks for using FixYa.
1999 Mazda Protege Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Yellow
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Yellow/Blue
Right Front Speaker Negative Wire (-): Violet/White
Car Audio Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow
Left Rear Speaker Negative Wire (-): Orange
Right Rear Speaker Positive Wire (+): Green/Orange
Right Rear Speaker Negative Wire (-): Green/Black
May 03, 2011 | 1999 Mazda Protege
Plugged in a Kenwood stereo in a 2000 tahoe. Have all power but no sound. Radio is not defective. When plugging the same stereo into a 99 express van, it works just fine. My question... What is the wiring...
Hi, your factory wire colors are below. Please let me know if you have more questions.
2000 Chevrolet Tahoe Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Feb 10, 2011 | 2000 Chevrolet Tahoe
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 4? x 6?
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
Auxiliary too quiet when using my iPod!
clean all conects with acohol and cheak for shorts
Jul 08, 2010 | Pioneer DEH-P7700MP CD Player
In radio mode, all speakers do not work
Radio will default to 2 channel stereo. You will need to use one of the soundfield processing modes to expand. Try using surround mode button to get to 6 channel or pro-logic.
Dec 29, 2009 | Sony STR-DE597 Receiver
Only 3 speakers play with ipod all other is ok
Are you playing your ipod through the stereo with a cable in aux mode? If so check your fader and balance settings when in aux.
there would be no other reason except for speaker wiring check and make sure there is no auxiliary wiring that may not be hooked up.
if it's not settings, then it's wiring, unless your stereo has an internal problem in the auxiliary circuit.
May 27, 2009 | Apple iPod MA446LL/A MP3 Player
No sound from all speakers except front left and front right
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Jan 24, 2009 | JVC TH-G30 Theater System
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Radio on but no sound
i have a 1994 eagle vision, with the premium sound system (infinity) and yes you do have a amp in your car if you have that sound system and its in the trunk of your car to the left while looking at your trunk from the back of the car :) also if you tryed putting in diffrent speakers other then stock thats your problem you have to rewire new speakers cant use old wiring because it goes threw the stock amp and for some reason the stock amp only works with the stock speakers :P
Oct 01, 2008 | 1995 Eagle Vision
103 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
