Question about Tatung Televison & Video
No tv picture and intermittent audio
Xfinity dta two days ago i get static instead of picture on all channels, and intermittent audio which cuts in and out with loud static bursts. Thanks!
  • Tatung Master
  • 3,320 Answers
Check the cables and connections
Posted on Apr 13, 2014
  • 1 more comment
  • Joy Sobeck
    Joy Sobeck Apr 13, 2014
    Thanks so much. I did check all the connections. I also unplugged the TV (an old Phillips tube model) from the power source for 5 minutes. I can watch DVDs fine using the TV and my SONY DVD player, just can't watch my cable TV. Thanks again.
  •  Mike M
    Mike M Apr 13, 2014
    Cable box may need a reset. Check on the back of the cable box for a reset button or switch.
  • Joy Sobeck
    I don't have a cable box per se; I have a digital transport adapter. I did try unplugging everything from the back of the DTA, then plugging it all back in. It made no difference. Thanks for your suggestions, though.
5 Suggested Answers
  • 44 Answers
SOURCE: Audio problem
Is this problem only on one channel? How is the sound on other tv's in the house? You may have a weak signal on this one channel
Lou Margo
loumargo@verizon.net
Posted on Mar 06, 2008
SOURCE: AKAI LCT3285TA static noise
Which input connections are you using?
Posted on Aug 01, 2008
SOURCE: Phillips 50PF9431D/37: Perfect Picture, inuadible audio
The audio or sound IC (integrated Circuit) on the TV panel maybe bad and need to be replaced.
Also, the speakers of the TV may have a weak connection from inside the panel.
But my best bet is the first solution i gave. If u are not a qualified electronics technician then take it to a service centre.
Joseph Asoh,
Abuja, Nigeria
Posted on Mar 12, 2009
SD Tech
  • 14553 Answers
SOURCE: Tv picking up channels except its all static, colorless, and loud static noise..
If the set was purchased in the USA it has the USA format which is NTSC--unless the signal is NTSC picture will be in black and white and no sound.
If the signal format there is PAL OR SECAM you will need a converter that takes that and outputs NTSC for the set to work properly there.
Posted on May 16, 2012
I have 37LC50CB LG tv. When I turn on with new DTA remote control come up channel # 56-1 and cloud(nothing) on screen Then I...
Your DTA remote cannot turn on your LG TV. Find the red/white/yellow cable that was in the box with your DTA and connect it between the appropriate RCA outputs on the rear of the DTA and the corresponding RCA inputs on the rear panel of your TV. Disconnect the cable connected between your DTA and the antenna input of your TV. Be sure your DTA is on. Turn on your TV and select your DTA as the input source. You may have to press SET UP on your DTA remote to display the set up screen on your TV. Do a channel search and you should be all set.
Nov 24, 2016 | LG Televison & Video
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
DTA remote: when bringing up tv guide menue, i can see it but cant use the numbers to scroll left, right, up, down-i dont see the remote help box
try using the volume control slide or the channel selection slide as they are normally the scrol controls
Nov 21, 2015 | Comcast XFINITY
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
How do I fix my xfinity X1 DTA box that changes to channel 8 when I shut of my TV at night and turn it back on in the morning?
Its main system control memory IC is faulty. LPM {Last Position Memory} function is not activates. Contact any service technician to replace it. http://electronicshelponline.blogspot.com/
Feb 07, 2015 | Televison & Video
Hdmi not supported
I have a Vizio E320VL - just hooked up the HDMI for the first time (4 years later) to work with my new comcast HD DTA. I'm getting "retrieving data" (with really weird audio sounds in the background) - then "not support." If I wait a few minutes, I can change the channel and get clips of video/audio with some intermittent gray snow and black screen - The longer I leave the TV on, the better this gets until its almost running fine 30 mins later.
Apr 08, 2014 | Vizio E320VL 32 in. HD Ready LCD TV
Scanning for channels
make sure you set the settings for catv (cable) not air (antenna). If any other boxes are connected to it first put them on channel 3 then scan.
Nov 20, 2013 | Televison & Video
Successfully hooked up Xfinity DTA to an older model analog Philips Magnavox TV/VCR Combo Model CCZ130AT, but cannot get the Xfinity DTA remote to sync with the TV, despite all of the 5-digit codes listed...
For the "power-on" function, you need to press another button before pressing "power-on". Like press "enter", then press "power-on". Then you should be able to find either a Philips or a Magnavox code that works.
Dec 21, 2011 | Philips CCZ130AT Combo
Purchased LG's LHB335 home theatre 5 days ago to enhance my LG 42LBX TV. Problem with home theatre sound as the audio cuts out for a couple of minutes every 15-20 minute intervals. Problem is intermittant...
i bought mine in january 2011 and just started having the same problem. i have to turn the head unit off and back on again to get sound back. any fixes for this yet?
Dec 06, 2010 | LG LHB335 Theater System
Is Audiovox VE1020 HDTV compliant?
Audiovox VE1020 is not a digital set. To see digital broadcast you will need another digital reciever or a long lead to connect to your existing one.
This set does not have very good reviews either.
Hope that helps!
Jun 06, 2008 | Audiovox VE1020 10.2 in. TV/DVD Combo
Televison & Video Logo
46 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
CoppellTVRepair.com
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
