Question about RCA Audio Players & Recorders
I have an rca m6204-b mp3 player and the headphone jack is so loose it won't even play music no matter what headphones i put into it, how do i fix it?
The headphone jack is very loose. I tried moving the headphone plug arounfd and it still won't work. it won't even play music at all, the serial number is FAB3NN432A3173, please help
SOURCE: Ear Jack
I had the same problem you had on a Dell DJ 30 I wrapped aluminum foil around my headphone jack and I plugged the headphones in. When I took my headphones out, the aluminum foil got stuck inside the player. I put the headphones back in and tested it and it worked. The aluminum foil is well placed in there and doesn't come out. I just did this a few minutes ago, so I am not sure of the long-term effects of this. Some articles I have read on the internet seem to suggest that this can cause a short-circuit. I am not sure and cautious about this. I will continue to use my mp3 player, but I might discontinue use in my car, for fear of shorting out my car speaker.
Posted on Apr 06, 2007
frit
  • 67 Answers
SOURCE: cannot hear music
The bad news is that your headphone jack is most likely shot. The soldered connections inside are most likely broken. This is not repairable generally, at least not for a cost that would be reasonable. Music will play through your computer because it can be read off your player through the USB connection. Use it as a data storage drive and buy a new one, or a used one. I've seen used T30s on Amazon for around $30 to $40.
Posted on Jul 29, 2007
techman
  • 3130 Answers
SOURCE: Audio Problems With MP3
First thing you wanna do is to try another set of headphones. If it still sounds muffled then theres a fault in the audio output section and these things are non user serviceable. Your gonna need to send back to the manufacturer. Good Luck
Posted on Apr 27, 2006
SOURCE: Left Channel is bad
This same problem has started recently on mine. I love it, and dont really want to buy a new one, has anyone had any luck on getting this problem fixed? let me know. htuntla@siue.edu Thanks
Posted on Sep 09, 2008
efs_perpends
  • 1996 Answers
SOURCE: how to fix a broken headphone jack on mp3 player
Have you tried another set of headphones? Normally the headphones wire is what goes, instead of the jack itself.
I've never opened one of those up, but I guess you could re-solder a new jack into it if you were adept at that sort of thing...Finding the right jack is the trick, I'm afraid.
I'd repost your question to the sandisk forum board here. Also see this list. It sounds like yours is a common complaint, and you may have good luck contacting sandisk technical support and getting it repaired...
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 07, 2009
Rca 5 disc changer rs2130i
Buy a lead with headphone jack to red and white RCA/phono. Jack goes to iPad/iPhone/MP3 player. Red and white goes to Aux/Game/Line input socket if the unit has one. Play your music.
Sep 01, 2014 | RCA RS2130i Shelf System
How to fix a coby headphone jack if no music is playing
Inside your mp3 the headphone jack may have been unsaludered or how ever you spell that :P Have an electrician open it and saulder it back and see if that was the problem....either that or ur headphones are *****....
Jul 04, 2010 | Coby MP-C7085 MP3 Player
I got my Element mp3 player six months ago and it
Save music to computer. Once music is saved format mp3. Reinstall music back. Then, open mp3 and solder headphone jack back. U should have a working mp3 with working headphones.
Sep 22, 2009 | Audio Players & Recorders
Zune only plays music out of one ear
When I first got my Zune the sound was really bad, but it turned out that I hadn't pushed the headphone jack all the way in. Don't be afraid to use a little force because it's necessary. I'm not sure if this is what's wrong or not, though. Hopefully it's a not a problem with the device.
Aug 28, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I CAN'T HEAR ANYTHING! HELP!
That has happened to me before, what happened was where you input the earphone jack was broken, no matter how many different headphones i tried none worked. Now I understand this doesn't help, but it might save a lot of time.
Although one short short term thing i did find out though, is that if you push the headphone jack to the side, sometimes you will receive a little sound.
Tinker13
Jan 23, 2009 | RCA TH1602 MP3 Player
Th1101A Sound Distortion
The headphone jack itself could be bad - time to replace.
Mar 13, 2008 | RCA TH1101 MP3 Player
Headphone prob
hmm...alright then.
1. Check the volume (but I expect you've probably done this)
2. Instead of putting mp4 or m4a on the computer try to put mp3 or wma on the player
3. Does the USB work too? The usb is also out of the headphone jack. If there's problems with that, then there's problems with the jack
4. Have you been pulling hard on the USB to take it out of the jack? If so the headphone jack part of the jack may have gotten a bit loose.
5. Call RCA. Chances are the person you get is from India. Talk slowly and tell them your problem.
Dec 13, 2007 | RCA OPAL M4001 MP3 Player
Cannot hear music
Mar 26, 2007 | iRiver T30 MP3 Player
55 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
