Question about Canon Pixma MX360 Printer
Cannot darken print
How do I darken the print on my printer and how do I print the entire page. It now is very light print and cuts off the last column of print
2 Suggested Answers
xptareq2000
  • 1447 Answers
SOURCE: PRINTER NOT PRINTING ENTIRE PAGE
this spot is opc drum i mean cartridge unite
change it then solve your problem
Posted on Sep 07, 2009
Is it possible to darken colors when printing a copy
You can usually can only alter or darken a print colour from the software program (i.e. Word), then send your document to the printer.
Feb 11, 2014 | HP Officejet 6500A Plus Wireless...
Even with new ink cartridge printer prints light
Double click Control Panel.
Double click Printers and Faxes.
Right click your printer and select properties. Now on General tab select "Printing Preferences".
Now select the basics tab and click "Advanced features" found on the right of the page.
Here you will be able to adjust the amount of ink that is used to print a page. Side the bar to the right to increase/darken the print.
Now click OK, followed by Apply.
Take care!
damnor01
Jun 07, 2012 | Office Equipment & Supplies
My scanned pages are too light.
Try to use the Lexmark All-In-One Center Application on your computer to adjust the darkness of your prints. On your computer, click on Start > Prorgrams > Lexmark 2600 Series folder > select All-In-One Center. From the Copy tab, select "darken" copies.
For printing, Normal or Best mode in the Print Setup properties before sending the print job to the printer for printing.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 19, 2011 | Lexmark X2600 InkJet Printer
Printer leaves black horizontal lines on right hand edge of paper
If you haven't already ran the head cleaner function try it first. If that doesn't fix it then you should try cleaning your print head. You can try windex and about 140+ water to try and cut all the ink clogged in the head. This cleaning method I have found out isn't always the solution and usually only lasts for a short period of time. While you in the printer look for any loose paper or foreign matter that could be causing the line. It has been my experience to just go ahead and spring for a new print head and get back to business. They're a little high but well worth it in the long run. I'm not familiar with the exact printer model you have but as printers in general go if it has a drum instead of cartridges you may have to go into it and clean it out. Check the screens and for clogging and also inspect the drum for any foreign matter caught in or around it that is making the line. A printer works in reverse order, when it shines light through the paper it is set to darken the entire sheet but light that is reflected back my mirrors prevents it from darkening the places that light is reflected back and therefore it only darkens the places where there is no light. If one of the reflecting mirrors has a spot on it and not sending light back it will cause a dark line, or if anything is in it's path that blocks the light it will do the same thing. Check this closely, to be sure the mirrors and screens are in no way obstructing the path of the returning light. The only other solution, which is highly unlikely is one of the LED that produce the light is burnt out but this seldom if ever happens. Most are wired where if one goes out they all go out, although I have ran across two that had one LED burned out. shgill
Sep 01, 2011 | Epson Aculaser C1100 Printer
Dell 922 printer will only print the last page of a three page document
In your software, choose "Print Preview" from the Print menu and verify that the entire document is there. If so, be sure that you are choosing to print all pages.
Nov 29, 2009 | Dell 922 All-In-One InkJet Printer
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
Ink lines darken the entire page
sounds like the toner cartridge is failing, try another one
Mar 07, 2009 | Samsung ML 1710 Laser Printer
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
Right Margin Does Not Print
This one work for me...on top left of the page click on file then click print. A box print with option opens...... click options then select or put a check on left bottom box that says print all linked documents....good luck!
2nd option or
Last option and 100% will print the entire page even allows you to select what you want to print inside the page. Its called webcollect and here is the link.......http://www.web-collect.co.uk/
Mar 21, 2008 | Canon PIXMA MP470 All-in-One Printer
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
Canon Pixma MX360 Printer Logo
16 people viewed this question
old marine
old marine
