Question about Hampton Bay Dryers
Ansley 52 " won't work
I purchased an Ansley remote controlled ceiling fan & it won't work ! All the dip switches are correct & electrical are too. Power is getting to the fan but the light or fan won't operate ? Please help Thank you !!!
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
Probably needs a new receiver. That's what you get when you buy a low-end store brand.
Posted on Apr 14, 2014
Our Hampton Bay 52 in. Ceiling fan lights will not shut off but the remotes will still turn the fan on and off.
More than you will have to replace that remote and receiver with a new one . They sell them at lowes homedepot menards. Its very easy to install the reveiver is mounted in the cover at the ceiling. Make shure you set the little dip switches in the controller and receiver to the same number before installing.Hope this helps.
Nov 05, 2010 | Hampton Bay 52 In. White Redington...
I have an Hampton Bay ansley 52" fan with light. How many wires should be coming out of top of fan.
The answer to your question can be found at this URL:
http://0000lx5.previewcoxhosting.com/manuals_fans.htm
For some reason I could not bring up the Ansley unit, but I think you will find the only difference in general is the size and shape. As long as you fan has a fan, lamps, and a remote control, the wiring should be the same.
In general a fan with lamps will have three wires coming out the top when used with a remote control: White - Circuit neutral Green or bare wire - Equipment ground, the third plug we have to deal with on many tools, etc, an inconvenience but an important safety device of sorts. Black or Red, etc - Power into the fan.
If the fan and lamps are to controlled independently of each other, there may be more wires coming out for connection to wall switches.
Important note - If you are installing a fan in this ceiling box for the first time, there are requirements for special fan rated ceiling boxes in order to be able to hold the weight of the fan and many municipalities require permits for ceiling fan installations - boiler plate CYA.
If you find this solution helpful, I would appreciate a Thumbs Up from you. If you require additional clarification, please contact me.
Be well. Paul
Oct 05, 2010 | Hampton Bay 52 In.Carriage House II in...
What is the code for the remote control to work the fan I accidently changed the 5 series code in the remote
You will have to look in your fan to find the dip switch for the receiver, depending on your model, it may be in the canopy at the ceiling, or in the switch housing where the light is, or possibly in the fan housing itself. Look your model# up and reply here and I can help you better.
Thanks
Sep 21, 2010 | Hunter 52" Ceiling Fan With Light And...
Ceiling fans turn themselves on.
Hello :
I don't want to scare you . But when your fans turn themselves on , that means there's someone else at home . Why I'm saying that ? It seems that you have a problem in home electrical wiring connections . You need to make test . You can stay in the room where are the fans and send someone else the turn on switches at home one after another until you find which switch is turning the fans on . You need an Electrician to correct this error at home and to wibe ghosts out .
good luck .
rate please .
Mar 20, 2010 | Hampton Bay 52 In.Carriage House II in...
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
Cannot set remote code for fan/light(dip switch)
The remote dip switch setting must match the fan receiver dip switches. Set them both to 2 on
Jul 04, 2009 | Hampton Bay 52 In. White Redington...
Two ceiling fans, both remotes control the same fan
Most likely the dip switches on the remote receivers don't match (on the second fan, the one that doesn't work). While the remote dip swithes on both remotes match the working fan. You can simply reset the dip switches on the second fan receiver to match the one working remote, i.e. you don't need to have a second remote, one can work both fans as long as the codes (dip switches match). If you want you can make all the remotes the same, that way you have two remotes, or if you want them independent each remote and remote receiver must have unique codes (dip switch settings).
Nov 30, 2008 | Universal Remote Control Hampton Bay...
No connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Dec 08, 2007 | Universal Remote Control Hampton Bay...
Dryers Logo
90 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
