How to fix proxy settings 127.0.0.1:9880
I can open any links that I click on, on another laptop. System tells me to go to settings, change pc settings, network and then proxy, but when I get there, I don't know what to do. Help!!!
5 Suggested Answers
  • 13 Answers
SOURCE: Client PC not able to ping WAN networks
Did you set reverse routing rules on the D-Link?
Posted on Feb 08, 2009
  • 79 Answers
SOURCE: When I try to sign into Yahoo Messenger 9.0 I get
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.
Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.
thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Posted on Jun 10, 2009
benwabnick
  • 2404 Answers
SOURCE: My screen is flickering too, but i found intresting response here
Try reseating the lcd cables on the lcd and to the motheboard as well.
Also if you want to verify if its a power problem with your wireless card causing the screen to flicker, remove the card completely and see if the flickering stops. If it does then its bad and the wireless card needs to be replaced. Remember that the wires for your wireless card comes from the LCD so it could quite possibly be a wiring problem as well, make sure there are no breaks in the wires that are being exposed cause that could cause problems.
Posted on Jul 04, 2009
SOURCE: Wireless laptop finds signal, connects to network but no internet
i lost my pc, if it connet internet, can i find that are
Posted on Sep 03, 2009
Proxy server not responding tells my to check my proxy setting what do i do
proxy settings are set in Windows Internet Explorer if that's a windows PC.
1. open internet explorer
2. click on the gear icon in the top right hand corner
3. click "internet options"
4. click "connections" tab
5. click "lan settings"
6. make sure all boxes are unchecked
May 08, 2014 | Samsung NP355E7C-A01US Series 3 17.3"...
In webfreer I cant connect through the net, the error is: A proxy server is a server that acts as an intermediary between your computer and other servers. Right now, your system is configured to use a...
solution is very easy..open webfreer..open settings..on the left side click extensions..update extensions..and enable secure https proxy
Aug 03, 2013 | Google Chrome
My IBM thinkpad wont connect to WiFi, it says i have to configure VPN... HELP PLEASE!!
Step 1:
Go to your network and sharing centre
Step 2:
click on the change adapter settings
Step 3:
right click and disable the network that says Microsoft on it
Step 4:
try to connect now.
Step 5:
if you need to turn off proxies still, check out this link
Feb 10, 2013 | IBM ThinkPad T40 2373 Notebook
Hola someone tell me how to change up into proxy server help.
What is your default browser? Settings for using a Proxy server differs from each browser. For example, The settings for Mozilla Firefox browser are as follows,
  1. Click Tools->Options;
  2. "General", "Connection Settings";
  3. Select "Manual Proxy Configuration";
  4. Enter proxy IP and port to appropriate fields;
  5. Click OK to close Connection Settings;
  6. Click OK to close Options;
  7. Reload browser.
You must also be aware that the use of proxy servers without the express permission from the owner of the proxy server may be illegal in some states and/or countries. Use at your own risk.
Using a Proxy server masks your real IP address with a masked IP address. You can ensure this by visiting www.IP-Details.Com and check your IP before and after using a Proxy server.
Nov 12, 2012 | Computers & Internet
Error 105 mcafee
Try this:
Open Google Chrome
Click Options > Under the Hood > Change proxy settings > LAN Settings > Uncheck "Use a Proxy server for your LAN.
Save the settings and then start using your chrome.
If problem still occurs then instead of Uncheck "Use a Proxy server for your LAN" kindly Check "Auto detect settings"
For instant use system utility tool Reginout having feature of Internet Optimizer that will fix this problem instantly.
Oct 11, 2012 | Google Chrome
What is proxy server address for asus pc 900
Click the "Tools" menu and select "Internet Options" to open the browser properties.
Click the "Connections" tab and select "Settings" to open the proxy server configuration.
View the section labeled "Proxy Server." This contains the Internet protocol and port address for your proxy server.
For Firefox
Click the "Firefox" menu, select "Options" and choose "Options" again from the menu that slides out
Click the "Advanced" tab and select "Network" tab. Click "Settings" to open your proxy server configurations.
View the section labeled "Manual Proxy Configurations." This lists the IP and port addresses for your proxy server
hope this helps
Sep 22, 2012 | ASUS Eee 2G Surf Notebook
I cant use facebook or youtube but i can use other internet sites
The sites are most likely blocked by a proxy program or internet content settings. Is this a work or school pc? if it is your personal pc and you can dictate the proxy settings, Open Internet Explorer, click tools, Internet Options, Select the connections tab, Click Lan Settings, Uncheck the option to use the proxy server. Try that.
Aug 28, 2011 | Computers & Internet
ERROR PROXY INTERNET EXPLORER
Google Chrome's connection settings and security settings are controlled by Internet Explorer's settings.
It appears by your error statement, that the Proxy Server settings in Internet Options has been changed to by pass the standard default of No Proxy Server. Sometimes Email Anti Spam Software can change this.
This should fix you up regarding the Proxy issue:
1. Click on Start and click on Control Panel.
Depending on your control panel view of Categories or Classic View:
1. Look for Network and Internet Connections category then Internet Options.
3. If in Classic View, double left click on Internet Options.
4. When Internet Properties opens, click on the Connections Tab and then the button LAN Settings near the bottom.
If the option to Use A Proxy Server... is checked then un-check it and click OK. Click OK again and re-open Google Chrome and see how it responds.
Let us know if you have further issues by using the "add a comment" link.
Thank you.
Apr 20, 2011 | Google Chrome
I have internet access but it tells me it cannot load the page because of proxy settings. I can't figure it out. I ran the recovery disc and don't know where to go from here.
How to change proxy settings
1. go to start 2. control panel 3. internet options 4. Click on Connections (tab on top) 5. click on LAN settings 6. put a check mark on Automatically detect settings and remove all the other check marks 7. click ok 8. click ok again 9. re-start pc 10. after it finish loading try to connect again and go online.
if it works for you don't forget to rate me if not let me know
thx
May 04, 2010 | Everex StepNote XT5000T Notebook
I formatted my system and reinstalled Win XP on it, but now I could not use wireless to connect with internet
Make sure you have Wireless network adapter driver installed.
Manually assigned IP address and DNS address as earlier (if your IP setting is not automatically assigned by DHCP server).
If you are using router set your Router IP address as your Default Gateway Address.
If you are using Internet through a Proxy Server then Open "Internet Explorer ",
Click "Tools",
Click "Internet options",
click on tab called "Connection",
Click "Lan settings" Button.
Remove "Automatically detect settings".
Tick "use a proxy server for your LAN....."
Type the IP address of your Proxy Server and the port no.
It will work.
Dec 26, 2009 | ASUS A8HE-X1 Notebook
Computers & Internet Logo
780 people viewed this question
David Payne
David Payne
