Question about Dehumidifiers
My vicks humidafier is blowing the vapor thru the bottom insted of the top.
  • 3,204 Answers
Sounds like it is blocked, could you give me the model number and i will see if there is anthing that can be done to fix this.
Posted on Apr 13, 2014
  •  Russ Hill
    Russ Hill Apr 13, 2014
    I have just been looking at a few of these and there is a filter on the system this needs changing or clean from time to time as it will get a build up of calcium and lime scale etc blocks the filter, hard water area should be more clean'd as the build up happen more you can find out if you have hard water by your hot water kettle if it has a thick scale on it.
Red light wont go off
Should have bought a Vicks! My red light goes OFF! No it easy. Unplug the unit for 10 minutes. Fill up with water while waiting. Turn it on! If the red light still come on then you gots scale or build up inside that needs to cleaned out. Follow or call manufacture on how to clean unit...
Jan 19, 2014 | DeLonghi Dehumidifiers
There is a hose hooked up so we don't have to empty the bucket all the time and it has stopped going through the hose - not sure why?
The reason it's stopped going thru the hose, is that either the hose is stopped up or the hose connection and interior tubing is clogged. When this occurs, water is diverted into the bucket.
The hose is easy to check for a clog. Remove the 5' section and either blow thru it or look thru it .
To clear a clog in the hose connection and/or interior tubing turn the unit OFF & unplug it. Then do the following
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connection hole . Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose for water flow to the floor drain.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hanger
Hope this helped you to solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Frigidaire Dehumidifiers
I have attached a hose and the bucket continues to fill - this has only started in the last two weeks - last year and prior to two weeks ago, it was draining well
From what you have described, either the hose is clogged or the hose connection tubing inside the unit is clogged.
The hose is easy to solve. Just, disconnect it and either blow thru it or look thru it.
If the clog is not in the hose, it's in the hose connection tubing of the unit. To solve this do the following:
1. Turn the Master ON/OFF Switch to OFF & Unplug the unit.
2. Using an 18" long, plastic Zip Tie or something similar (NO wire coat hangers, though) that is appropriately sized to fit in to the hose connection tubing .. Carefully insert the Zip Tie and continue to push it in, until you reach a bend in the tubing. You must gingerly work the Zip Tie past this bend, until it either bottoms put or you run out of usable Zip Tie. Now, slowly remove it while rotating (twisting) the Zip Tie. This will dislodge any clogs. As you reach the inserted end of the Zip Tie, be prepared for some water to follow.
To avoid clogs in the future, clean the air intake filter regularly. At least once every two weeks.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Whirlpool 25-Pint Dehumidifier
Wont drain through the hose
More than likely, te problem lies within the hose or the hose connector tubing inside the unit. Either one is clogged. The hose is easy to inspect. Just remove it and either blow thru it or look for light at the opposite end of the hose. If there's nothing there, then it's in the hose connector tubing.
Using an 18" long, plastic Zip Tie ( or something similar. NO wire coat hangers though) that's appropriately sized to fit the hole. Carefully insert the Zip Tie and continue to work it in, unit you reach the bend in the tubing. You will need to gingerly work it past this bend, until it either bottoms out or you reach the end of usable Zip Tie. Slowly pull the Zip Tie out while rotating (twisting) it. This will break up any clogs. As you reach the inserted end of the Zip Tie, be prepared for some water to follow.
That should take care of it. Also, if your bucket has a Float Valve in the top of it, make sure the Float Valve is in the Down position. If it's stuck in the UP position, gently shake the arm to make it return to the Down Position.
Jun 28, 2011 | Frigidaire FDL60P1 Dehumidifier
The hose stopped draining the water. How do I reset?
It's not a question of how to reset the unit. It's a question of how to unclog either the hose or the hose connector tubing inside the unit.
The hose is easy to check and unclog. Turn the unit OFF and unplug it. Disconnect the hose from the connector and either look thru it or blow thru it. If you see light at the other end of the hose or air blows thru freely, the clog is not in the hose. It's in the hose connection tubing.
Using an 18" long, plastic Zip Tie, that's appropriately sized to fit in the hole of the hose connection. Carefully insert it unitl it reaches a bend in the tubing. Gingerly work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Slowly pull it out while rotating (twisting) it. This will dislodge any clogs. As you reach the inserted end of the Zip Tie, be prepared for some water to follow.
If you don't have an 18" long Plastic Zip Tie and don't want to run out to get one, you can use something similar that is flexible and log enough. DO NOT use a wire coat hanger.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 28, 2011 | GE AHG50LB / AHG50LD Dehumidifier
How do i start this humidifier?
fill with water - the water conducts electricity and in a few minutes will produce steam
Dec 18, 2009 | Kaz Vicks Natural Mist Humidifier...
Water goes in reservoir, not thru hose to sump pump, leaking
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
LG 65EL water not dripping to bucket
THE DRAIN LINE IS CLOGGED TAKE OFF THE HOSE FROM THE UNIT AND BLOW AIR BACK THRU THE UNIT,, IT IS NOT UNDER A PUMP SYSTEM IT IS GRAVITY, IF IT WON'T DRAIN IT'S CLOGGED
May 29, 2009 | LG LD65EL Dehumidifier
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Apr 07, 2009 | Kenmore 54701 Dehumidifier
Ice on dehumidifier
A dehumidifier works by cooling the metal pipes on the back of the unit to create condensation (water vapor in the air). This then drips into the collector bucket. If the unit runs too long the cooling tubes can get too cold and freeze the condesing water vapor. Unplug the dehumidifier and let the ice melt, when u turn it back on, turn it down, it may be up too high. If you find this solution helpful please rate it.
Thanks - Tech101
May 20, 2008 | LG DH404E Dehumidifier
Dehumidifiers Logo
23 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
