Question about Whirlpool ED5SHAXM Side by Side Refrigerator
WATER DOES NOT DISPENSE FROM DOOR
WATER DOES NOT DISPENSE FROM REFRIGERATOR DOOR BUT ICE WILL DISPENSE FROM REFRIGERATOR DOOR ON ED25PQ REFRIGERATOR.
Sounds like the water solenoid valve poppet is sticking in the closed position. You will need to replace the assembly. It is located behind the fridge at the lower corner.
Posted on Sep 26, 2009
No water or ice coming from the dispenser, ice is being made. Cannot change the freezer temperature
Fix your GE refrigerator door ice and water dispenser ...
? 18:47
www.youtube.com/watch?v=8yNWbNaNCOA
Oct 20, 2013 - Uploaded by StewTube
Fix your GE refrigerator door ice and water dispenser and save ...it makes ice but no water or ice come out from the dispenserAnd if it's the ...
Oct 24, 2015 | Refrigerators
We have a side by side Whirpool Ref Model #ED25PQ. It makes ice and despense ice inside the ref into the ice tray. Our problem is with the door closed we are unble to get ice thru the door into the...
I don't know if this is your problem, but my sister had this problem before. When I checked the area, it was clogged with dried soda. The kids allowed it to splash up when ice dropped into the glass. The sugary drinks will dry sticky and not allow the dispenser to dispense. I used very hot soapy water several times to melt the sticky buildup. Her fridge has been working every since. Good luck, it this is your solution
Aug 18, 2013 | Whirlpool ED5FTGX Side by Side...
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
Ice does not dispense from whirlpool refrigerator. Model # ED25PQ If you press with a cup or glass to attempt to get ice whether it's cube or crushed there is no noise or ice being sifted through.
Check the ice cube container to see if it is full of cubes and also that the cubes are nor "bridged" above the dispenser auger. Hope this helps!
May 30, 2011 | Whirlpool Refrigerators
ED25PQ quit making ice. Water dispenser still working
Pour about 1/2 cup of water into icemaker . If it harvests(dumps) then problem is the water valve.....if not , then icemaker is the problem .
Jun 26, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
Whirlpool Refrigerator/Freezer Model # ED25PQ
Hi!!!Hi!!! change your ice maker control module on your icemaker its letting to much water it show here its the one with with the white round wheel..change it and all should be fine..googd luck..
Jan 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Nov 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Rfrig Whirlpool ED25PQ
The door on my ice maker does not close so frost develops on the maker itself. How do I fix this?
Apr 16, 2008 | Whirlpool ED5SHAXM Side by Side...
Whirlpool ED5SHAXM Side by Side Refrigerator Logo
284 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
