Question about NEC Audio Players & Recorders
Nec microwave always tx mute
Does anyone know where i can download the nstruction manual for a NEC microwave Model No:N668E
I would try the NEC web site. You may want to double check the model number first.
May 16, 2016 | Microwave Ovens
How can sound be muted on ffcmo934ls a Frigidaire microwave oven?
I appreciate your inquiry, friend!
From what you have described you would like to mute the sound on your Frigidaire microwave, FFCM0934LS. I have researched your microwave and I was unable to any instructions on how to mute your sound. Unfortunately you are unable to perform that operation on your microwave. I hope this is helpful information. -Matt
Mar 03, 2015 | Frigidaire Microwave Ovens
How do I turn the mute off
I had this mute problem and found that unpluging it for 1 to 2 min. and the problem cleared.
Oct 05, 2014 | GE SpaceMaker Microwave Ovens
Why does my new Honda CB always show RX receiving transmission no matter where squelch is set?
if this is on a Goldwing, it appears that you have a shorted pin int he connector. Disconnect the radio and make sure all of the pins are straight and connecting properly.
Oct 02, 2014 | Radio Communications
Why my nitsuko tx serise nxe2464m tx extension phones are not riging
Ringing is assigned in system programming, either a tech or your office in house tech will need to make the change.
Jul 03, 2014 | NEC Dterm DTP 16D-1 Corded Phone
HOW DO YOU PLACE THE PHONE ON MUTE?
Feature - 1. The light will go out above the MIC text indicating that the microphone is turned off.
Aug 06, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Wattage of NEC microwave oven
Look on the back of it and you will see it. I would say 700 watts
Mar 12, 2009 | Microwave Ovens
Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Mar 04, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR605 7.1 Channels... Problem
firmware up date go to onkyo homepage
Apr 01, 2008 | Onkyo TX-SR605 Receiver
My NEC Dterm Series E 16D-1 does not display the MUTE feature
Sir, a co-worker with this phone has the same problem, i have a fund the users manual for the phone and the code to turn on/off the mic is Feature then the number 1. for her the mic button lights up when the phone is off. meaning no one can hear her. the link for the users guide is.
http://www.chickasawtel.com/pdf/manuals/elitemultilineug.pdf
hope this helps.
Nov 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Open Questions:
32 people viewed this question
Top NEC Audio Players & Recorders Experts
richie46
Outback Jack
Outback Jack
Ravi
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
