Question about Toshiba Televison & Video
How to play video cassette with TOSHIBA SD-V391 DVD PLAYER/VCR VIDEO CASSETTE RECORDER
  • 158 Answers
SOURCE: DVD tray keeps opening and closing?
this sounds like the take up motor for dvd player the band maybe streached have you got it serviced latley as this maybe the cause of problem this is due to heat from dvd player and vcr comby drives please have it looked at by an expert in this field as my sony dvd player and vcr does the same as you've described
Posted on Aug 13, 2007
SOURCE: toshiba dvd Video player & vcr SD-V396SU2
Thanks. We have replaced the unit with a JVC but will give the SP/SLP a try just to see.
Anoyed
Posted on Dec 13, 2007
SOURCE: Sony SLV-D360P DVD Player/Video Cassette Recorder
make sure the tv is on channel 3. i had the same problem and it fixed by going to channel 3.
Posted on Aug 23, 2008
simplemitch
  • 752 Answers
SOURCE: External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Posted on Sep 09, 2008
SOURCE: my vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Posted on Nov 09, 2008
Toshiba dvr19dtkb2 dvd wont play on computer after transfering form video casette
The proper codec may not be loaded on your computer. Find the format your DVD recorder uses, Google for a codec for that format. Find a player that supports the code, download and install it onto your computer and then try the DVD.
Mar 31, 2014 | Toshiba DVD/Video Cassette Recorder...
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
Trying to do a timer recording to a Toshiba SD-V296KU DVD Video Player/Video Cassette Recorder. all seems to go with the recorder device but when I do the playback it is a blank screen. Is that because the...
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Mar 01, 2011 | Sansui HDLCD-4212 LCD TV
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Need to find the manual for my toshiba dvd-vcr combo sd-v391
I have bought this combo unit and the DVD works OK but I get nothing from the VCR
Apr 19, 2009 | Toshiba Computers & Internet
Toshiba model sd-v383sc
Atrk means that the unit is in auto-tracking mode and trying to lock in to the tape's recorded speed. This should go away after a short period of time once the tape has started.
Dan
Jun 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Sanyo DVD Player & Video Cassette Recorder - DVD-7200
dvd does not play but video cassette does...fixable???????
Apr 16, 2008 | Sanyo DVW-7200 DVD/VCR
VCR thinks ALL tapes are write protected.
the record tab detection switch inside the machine is broken
Dec 12, 2007 | Toshiba SD-V392 DVD Player/VCR
Toshiba dvd Video player & vcr SD-V396SU2
Anoyed
Nov 29, 2007 | Toshiba SD-V394 DVD Player/VCR
Jun 24, 2007 | Toshiba M754 VCR
Televison & Video Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
