Question about Boating
Haenel air rifle
How do I dismantle the barrel to get at the piston and spring?
  • 88 Answers
SOURCE: Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Posted on Aug 11, 2009
  • 88 Answers
If the trigger is adjustable set it more coarse to hook the piston rod. Make sure trigger is loose and will reset to it foremost position. Check trigger spring and pin for ease op operation. Lastly check if piston rod did not turn inside cylinder so hook is turned away from trigger.
Posted on Aug 29, 2009
agent91
  • 2100 Answers
SOURCE: pelet rifle won't fire
Does it leak out?, pump up?, trigger release anything? What are the symptoms? Anything stuck in the bore? I think Crosman will repair your gun at a fixed price, just get a hold of them and get permission to send it back.
Posted on Feb 13, 2010
  • 79 Answers
SOURCE: Hi, I received a Crosman
Hit the top of the barrel with your hand. Don't be afraid to give it a good whack.
Posted on Jan 08, 2011
19ken55
  • 426 Answers
SOURCE: Benjamin 392 air rifle leaks
Put oil in barrel in chamber and clean out dirt with compressed air.
BE CAREFUL
Posted on Feb 01, 2011
I changed the main seal on my .22 gamo air rifle when l put the rifle back together and break the barrel to **** the tigger l now find the trigger does not engage?
Sounds like you left a spring out. As the piston goes back, it get to a place where a spring locks a sear in place that is connected to the trigger.
Mar 19, 2018 | Optics
My vantage np has very little pressure. Will not fire the pellet.
It is either the o-ring seal at the break barrel, or the the piston seal, or that the nitro piston is leaking. Contact Crosman direct using the link at the bottom.
Nitro Piston
A recent innovation introduced by Crosman is the Nitro PistonĀ® power plant in which cocking the rifle moves a piston to the rear, but instead of compressing a spring, a gas (nitrogen) in a cylinder is compressed. When the rifle is fired, the compressed gas propels a piston forward to compress air in the receiver behind the projectile. The advantages of the compressed gas as a power source (sometimes called a gas ram) include lighter weight, a great reduction in noise and vibration, and the option to leave the rifle cocked for extended periods which might cause weakening of a spring.
Crosman
Mar 06, 2018 | Pool & Spa
I have a F4 crosman air rifle and I can't find the place where the co2 goes I need help
It is a break barrel air rifle that when it is cocked the piston is pushed back drawing air into the cylinder so that when the barrel is closed the breach seal covers the transfer port squeeze the trigger piston flies forward forcing the air through the transfer port into the barrel accelerating the pellet up the barrel and towards the point of impact
It is not a co2 powered air weapon
Oct 20, 2017 | Crosman Optics
Good day my is Wade my Swiss Arms air rifle has got no power when shooting.
there is no air rifle suitable for south african hunting conditions.
Sep 09, 2016 | The Optics
How to fix air pump
The crossman phantom is a spring powered air rifle which means that you pull the barrel down through the arc of its travel until the piston locks up to the trigger mechanism in one continuous movement
Feb 08, 2016 | Crosman Optics
Beemans sportsman rs2 trigger system not engaging after the break barrel been bend goes blank
Do you mean that you have never been able to cock the rifle ever
Like get the piston to lock up to the sear if so
Return to where you purchased it and get them to sort it
Mar 17, 2015 | Optics
Jun 01, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Crossman Phantom break barrell air rifle will not **** after breaking the barrell open. Any suggestions as to the problem?
The barrel pushes the piston back when you **** it.
The seer grabs the piston to hold it.
It sounds like you have an engagement issue between your seer and piston.
Often there are springs which hold the triger paul and seers in place. You may have lost a spring which isnt allowing your trigger mechanism to reset after the trigger is pulled. This results in the trigger being permanitly in the fired position.
Good luck and hope this gives you something to look for
Mar 10, 2009 | BSA Air Gun Scopes
Feb 08, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Boating Logo
56 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
