Replacing a factory toner cartridge
It's about small rounded toner with two switched positions: locked and unlocked. When locked, everything works fine. When you twist it for 30degrees and unlock, I can not pull it out. I am afraid If I apply full force. Any tips please? pc-servis-kompjutera-kod-fontane.blogspot.com
  • 3,904 Answers
They are pretty tight fitting so don't be afraid to get a little more aggressive. Some of those, after in unlock position, need to be pulled back and then up.
Posted on Apr 13, 2014
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Se puede resetear el contador de los tambores de la oki c3400n
Trata esto:
When installing the C3400n printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result. Note: (Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
          0.408?openelement&fieldelemformat=gif
    >> Insure the toner is fully locked, see photo below showing the correct and incorrect positions of the locked toner cartridge.
CORRECT (Fully rotated to lock position)
    91.28a2?openelement&fieldelemformat=gif
INCORRECT (Not fully rotated to lock position)
179.32a2?openelement&fieldelemformat=gif
Dec 01, 2010 | OKI C3400n Laser Printer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
How do you change out the black toner?
If you can not rotate the toners by using the DISPLAY MENU,
You can rotate them MANUALLY, using a flat head screwdriver or even a key for your car or front door.
Open Front Cover/Door of Printer
Remove Waste Toner Box
Where you see the side of the Blue Cartridge, look to the LEFT and locate a small rectangle with a circle inside it.
Push your car key or flat head screwdriver into this rectangle and the circle will push back and release the lock on the cartridge, holding in with one hand and turning cartridge with the other hand until you get the cartridge you want to replace.
Remove the screwdriver / car key and pull out the empty cartridge and replace with new one.
Replace Waste Toner Box, close front cover/door, switch on and the printer will rotate back itself to it's normally position...... JOB DONE
Jan 19, 2010 | Minolta magicolor 2300W Laser Printer
Everything prints on left half of page
First, are you using a factory Xerox cartridge and Xerox toner?
As to the document, are you getting the entire document printed or is the document simply cut off as if the printer cartridge is out of position?
Oct 19, 2009 | Xerox Phaser 6180N Laser Printer
Replace belt CG
Set Belt CG The OPC belt cartridge needs replacement.
Replacing the Optical Photoconductor (OPC)
Belt Cartridge
Replace the OPC belt cartridge at least once every 12 months, or when
the control panel display indicates that replacement is necessary. The life
of the OPC belt cartridge for the T8106 is about 60,000 images (15,000
color pages), at a 5% toner coverage rate on letter-size paper.
1. Turn the power switch off.
2. Unlock the lever to open the front
cover. This releases the pressure on the
toner cartridges.
3. Unlock the lever to open the top cover
fully.
4. Pull the green OPC belt cartridge lock
levers up until they unlock.
5. Pull the used OPC belt cartridge
upward and out of the printer carefully
to avoid spilling toner.
6. Discard the used OPC belt cartridge
Caution! Do not touch or wipe off any powder that is on the OPC belt, nor expose
the OPC belt to light.
7. Remove the two shipping pins from the
new OPC belt cartridge.
8. Remove the protective sheet that covers
the photosensitive belt.
9. Slide the new OPC belt cartridge downward
into both green lock-lever guides
and into the printer carefully.
10. Push the green OPC belt cartridge lock
levers down until they lock.
11. Close the top and front covers carefully
until they both lock.
May 28, 2009 | Tally T8106 Laser Printer
FATAL ERROR
your printer is laser printer change toner cartridge right,
you may try
1) Open the front door and remove the toner cartridge.
2) you will see a small round hole near the colour toner cartridge
3) hold a screwdriver in that hole and the carousel will rotate freely. 4) Move the carousel round and remove each one of three cartridges at a time.
set back all cartridge close door.
Jan 29, 2009 | Konica Minolta magicolor 2300DL Laser...
Okui 3530 toner sensor error
turn off eq - open and remove the drum with the color cartridge in locked position still in place - on the drum on the cartridge lock side you will find a small (1/4 ") rectangular "window"...with the catridge in locked position the window should be open so you can see the sensor...when the cartridge is unlocked the window should be closed...so with the cartridge locked, using a tiny pointed object (paper clip), gently move the panel up or down to the open position (mine moved up)....replace the drum with cartridge...make sure it is set properly...close up everything and turn eq back on....you may have to do this two or three times to make sure the window stays open when the lock is engaged...but this is what the "tech"(salesman) did...good luck
Nov 10, 2008 | OKI C3530N Color MFP Printer
Toner
Push up on the release latch on the Right Side Cover to open the cover
  1. CAUTION: Ensure the side cover is always open before opening the front cover.
  2. Open the Front Door.
    Turn the orange Toner locking lever up to unlock the Toner Cartridge.
    Pull the Toner Cartridge out of the machine.
  3. Remove the new Toner Cartridge from the box. Save the box and the packaging for storing the old cartridge.
  4. Gently shake the new cartridge horizontally 4 or 5 times to loosen the toner. Be careful of any Toner spill.
    NOTE: Shaking the cartridge will ensure maximum copies per cartridge.
  5. Slide the new cartridge into the machine until it locks in place
  6. Turn the Toner locking lever down until it locks in place.
    IF it is not sliding in. remove the cartridge and on the back of it, there is a round drive you may have to spin a quarter turn and reinsert. Sometimes that doesnt line up
May 19, 2008 | Xerox FAXCENTRE 2218 18PPM FAX
Fatal Error 17H - toner cartridges will not advance
Open the front door and remove the toner bottle.
Look near the colour toner carts and you will see a small round hole. Jam a screwdriver in that hole and the carousel will rotate freely. Move the carousel round and remove each toner one at a time.
Oct 10, 2007 | Konica Minolta magicolor 2300DL Laser...
jasbo
jasbo
